Old 12-22-2004, 05:28 AM   #1
needing_a_supra
needing_a_supra is on a distinguished road
are the 87 to 92 supra blocks aluminum or cast iron? ive noticed on every site people complaining about head gaskets and usually aluminum heads on a cast iron block will cause the head gasket to blow or leak. and is it a posi track rear end (both back tires spin not just 1)?
thanks
needing_a_supra is offline   Reply With Quote
Old 12-22-2004, 05:40 AM   #2
briananh
briananh is on a distinguished road
yes, the block on that year supra in cast iron. Typically, the head gasket blows because of the lack of cooling of cylinders 5 and 6. bad engineering for that head. I've heard a story about some owners using the old style head. 5m or the 6m. better flow and cooling, not to sure
briananh is offline   Reply With Quote
Old 12-22-2004, 07:31 AM   #3
the_fallen
the_fallen is on a distinguished road
the blowing head gasket problem was not due to head design faults, was due to torque settings not being high enough. retorque the head and you don't have a bhg problem.
the_fallen is offline   Reply With Quote
Old 12-22-2004, 10:04 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
Pics of my build.
Do a diagnostic first!
Old 12-23-2004, 07:47 AM   #5
Guest
Guest
Posts: n/a
:unsure: Thats just wrong :wacko:
Try head studs
