Old 09-14-2005, 10:53 PM   #1
VigilanteVixen007
VigilanteVixen007 is on a distinguished road
Default Need torque specs...
Hi all...was wondering if anyone could help...
I need the torque specs on the cam shaft bearing caps for a 1988 supra 3 liter dual overhead cam ...thanks in advance
VigilanteVixen007 is offline   Reply With Quote
Old 09-15-2005, 04:42 AM   #2
Poodles
http://www.cygnusx1.net/supra/librar.../em/EM_32.html
shows it should be 14ft-lbs
Old 09-15-2005, 08:56 PM   #3
VigilanteVixen007
thank you so much!!
Old 09-15-2005, 09:02 PM   #4
VigilanteVixen007
here's one more question...
when installing camshaft sprockets at 12:00 for replacement, do they have to be at a specific compression stroke like a crankshaft #1 cylinder on compression stroke top dead center, or can the head simply be installed with both sprockets at 12:00?
Old 09-16-2005, 03:51 AM   #5
Poodles
That website is the entire factory service manual, if the answers aren't in there, i might be able to find it from my other manual, but I doubt it.
But, I think you mean on lining the sprockets to the camshafts? I think there are 3 ways they can go on, and the middle way is the right way. Then, once that is done, they have matchmarks that match up to each other to line them up.
I know there are more knowledgeable people on the forums on this... but I think the sprockets have changed over the years too...
Old 09-19-2005, 11:47 AM   #6
the heads are non interference so you can stick the head on any way... just make sure the locating pin is in the middle of the sprocket
stick her on and set your timing up once it's torqued down
Torque Specs 87MK111Supra MKIII Supra 7 03-09-2009 10:28 PM
ct26 torque specs tak2099 MKIII Supra 0 01-28-2009 04:51 AM
factory specs? burton51m MKIII Supra 6 10-16-2006 07:44 PM
Torque specs for steering rack on mk4 dini_the_owl MKIV Supra 1 09-15-2006 11:48 AM
engines and specs for the mk3 suprra_girl MKIII FAQ 0 12-29-2004 12:20 PM
