Old 11-23-2006, 12:11 AM   #1
Chomper
Chomper is on a distinguished road
Default Check Engine Light & Warning light on
I don't know why my check engine light and warning light (on top of speedometer) are on. I have a 93 na supra. The first time they came on for about 10 secs then turned back off. The next day after, it turned on continously. Today I thought I felt the engine idling wierd at a stop. Can anyone please help me out with this?
Chomper is offline   Reply With Quote
Old 11-23-2006, 07:02 AM   #2
SupraDupra
SupraDupra's Avatar
Almost sounds like an O2 sensor on it's way out ,but before you run off and buy one you should get the diagnostic codes from the car to be sure.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-24-2006, 04:16 PM   #3
You should be able to check the code using this procedure:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
Old 07-02-2007, 07:18 AM   #4
geoff
geoff is on a distinguished road
hello mine did the same yesterday and when it started it felt like it was misfiring then when i turned it of and back on it was ok should i go down the same check list as you suggested ?
thanks for the help
geoff is offline   Reply With Quote
Old 07-02-2007, 11:14 AM   #5
Did your check engine light come on when it was misfiring?
Old 07-02-2007, 12:46 PM   #6
geoff
Thumbs up light
yes the red light in the middle of the rpm stayed on and the engin light stayed on i have taken the car back to the place i got it from and they are going to check the ecu on saturday
looks like you were spot on m8t thanx for all your help
Old 03-29-2009, 05:06 AM   #7
jza80rz
jza80rz is on a distinguished road
Default engine warning light :(
i too have the same problem, but not only does that light go on but others aswell including oil light, battery light, i think heating? (looks like a cat with heat waves coming out) and i think rear lights..
first of its very weird because i know the car has been serviced reguarly by toyota, i recently bought the car and yeh shes mechanically A1 besides the lights which only come on every now and again..
i was browsing around and came across this.. http://www.mkiv.com/techarticles/eng...bd1_codes.html
"The ECM stores the code(s) until it is cleared by removing the EFI No. 1 fuse with the ignition switch off."
First off i know that oil is fresh as i change it every 3000kms with motul chono v, and replace the oil filter and use e30 engine treatment. and i know the oil is at the right level.
next is if that cat symbol with the heatwaves means coolant/overheating thats impossible because the cars temp gauge does not show any overheating, however though when i do turn the car of i hear gargling sounds.. coming from the coolant pipes. if anyone has something to add on that please do.
with the rear light symbol, i guess thats my rear lights which work well except for the small centre brake light with the leds, i have about 4 which arnt working but im pretty sure that shouldnt show up as a fault?
and battery, car starts up fine everytime, alternator is good.. though i do have a sub connected (previous owners) maybe some faulty wiring.
Ok, this is what im planning to do..
oil change & new oil filter plus e30 engine treatment and oil flush
coolant flush, then coolant chnage and bleed out any bubbles
spark plugs iridium ngk's im thinking BKR6EIX-11
flush brake fluid via bleeding, then new dot 4 fluid
transmission oil change castrol vmx, with nulon g70 treatment additive
and last but not least air filter clean
after all this i plan to disconnect the battery, then reconnect it start her take her for a spin.. and if i still get the warning lights ill refer to "The ECM stores the code(s) until it is cleared by removing the EFI No. 1 fuse with the ignition switch off." and give that a go.. if the lights still come on im screwed guys
PLEASE DO add any suggestions or comments!
jza80rz is offline   Reply With Quote
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
check engine light suprakid91 MKIII Supra 0 10-19-2007 07:33 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
