Old 05-30-2006, 08:14 PM   #1
hobbes
hobbes is on a distinguished road
Default A/C question - Suspension Q
I have a 95 N/A Supra 5 speed. If you take out the A/C do you get a noticable hp gain?
Also, I need to replace my struts and figured I would get a new suspension. What are some good brands to look at?
Thanks
hobbes is offline   Reply With Quote
Old 05-31-2006, 12:27 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Although I'm less familiar with na's (perhaps other member(s) can post here as well), I'd have to guess that you wouldn't gain much HP from removing the A/C versus simply turning it off. Most folks I know that completely remove the a/c do so for weight savings, and possibly to increase airflow to the radiator.
The Mkiv Supra doesn't have struts, it has a double-wishbone suspension with coilover shocks. A couple of good replacements for the oem shocks are Koni and KYB (AGX). If you want to go to a full coilover system, Teins are very popular.
Life begins at 30psi.
Old 05-31-2006, 07:55 PM   #3
hobbes
Yea I think I might go with Tein for my suspension. However with the A/C I heard that it uses a belt in the engine and when you take it out you remove that belt which would give you extra horsepower. Has anyone heard of this?
Thanks in advance
Old 06-01-2006, 12:44 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
...with the A/C I heard that it uses a belt in the engine and when you take it out you remove that belt which would give you extra horsepower. Has anyone heard of this?...
The same belt drives the a/c, power steering, fan+water pump, and alternator. If you remove the a/c compressor, you'd still need a belt (just a shorter one).
Old 06-01-2006, 02:24 PM   #5
hobbes
Also, when I took it in to have it looked at the guys said that the "struts" were leaking hydraulic fluid and wont pass inspection. If the car doesnt have struts what were they talking about?
Old 06-06-2006, 12:04 AM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Probably the shocks...
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
suspension question mkiiisupra88 MKIII Supra 0 05-25-2006 07:24 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
suspension question da89soup MKIII Supra 4 12-13-2005 11:28 PM
