Old 02-24-2006, 03:11 AM   #1
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
Default My Supra is being fixed :)
Well I?ve ordered everything from Titan motorsports and now I just have to wait for the parts(or engine) to get here
Here?s what I bought
New Toyota Supra Shortblock
New Toyota Supra Head
ARP Head Stud kit mkiv
Fidanza Racing Lightened Flywheel /orginal=36 pounds, Fidanza=15pounds
Apex S-AFC II Special Edition(fuel computer adjusts air/fuel ratio)
Titan Motorsports 2JZ-GTE Cam Gears
Greddy Iridium Spark Plugs
And all the packages that are needed
And here are the mods that are allready installed
Sry for not having the right information last time
HKS 4" exhaust with a Downpipe
HKS Fuel Cut Defenser
Greddy Profec B boost controller
Blitz Cone airfilter
FMIC with HKS Piping
Blitz Dual Turbotimer
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
Old 02-24-2006, 05:39 AM   #2
Originally Posted by SupraTT/Iceland
...New Toyota Supra Head...
What was wrong with your current head?
...HKS Fuel Cut Defenser...
If you're going to continue using the oem twins in sequential mode, you need to get rid of this HKS FCD and purchase a GReddy BCC.
Oh, and why didn't you order the shortblock and head from your local Toyota dealer?
Have you purchased a new gasket set from Toyota yet?
...and you don't need to run head studs (vs oem head bolts) unless you're planning to run a huge turbo & upgraded fuel system in the near future.
Old 02-25-2006, 11:22 AM   #3
jamie chapman
jamie chapman's Avatar
jamie chapman is on a distinguished road
Thumbs up
that some money u spent there mate cant wait to see afinished picture of what sort of bhp you gonna be running
jc
jamie chapman is offline   Reply With Quote
Old 02-26-2006, 12:32 PM   #4
SupraTT/Iceland
The head was destroyed when the block was destroyed. Because of low octane one piston has got a hole in it and it went through the piston and into the block and destroyed it.
The FCD seems to work fine. No fuel cuts anyway.
The shortblock and head costs alot more if I would have bought it from my local Toyota dealer. And yes I?ve purchased a head gasket and all other things I need.
I?m maybe thinking of upgrading to a larger turbo and fuel system in the summer.
Old 03-20-2006, 02:31 PM   #5
...The FCD seems to work fine. No fuel cuts anyway.
Yes, but it'll wreck your oem twins. More info here:
http://www.mkiv.com/techarticles/bcc...GReddy_BCC.htm
...I?m maybe thinking of upgrading to a larger turbo and fuel system in the summer.
Unless you're going to a HUGE turbo (74mm or larger), you won't need head studs...the oem head bolts work fine.
