Old 02-11-2006, 08:36 PM   #11
Originally Posted by SupraTT/Iceland
I?m trying to get a hold on one of the previous owner because I know now that there is a another ECU in the car it?s not Stock. Much more gas flow. But I don?t know what kind.
But one thing is weird this car has always been over 20 psi with no problems but maybe 26 psi was just to much. I?m trying to get more information about what exactly has been done.
A change in "gas flow" wouldn't be sufficient protection against high boost and low octane.
Oh, and fwiw I wouldn't exactly call a destroyed piston "no problems". Problems like that don't typically happen all at once either...every time that car has been run with too much boost on too little octane, the damage gets worse and worse...until a piston fails.
Old 02-11-2006, 09:11 PM   #12
SupraTT/Iceland
SupraTT/Iceland is on a distinguished road
But I thought there were alot of supras that are daily driven and are over 500 hp ? are you saying that you all drive on race gas ? That is really expensive especially for a daily driven car.......and you have to take into consideration that the normal gas here costs 7 dollars a gallon .....it costs much more here then in Usa
But how many hp can I be expecting if i have the boost at 16 psi ?
with a 3" inch HKS Turboback exhaust, Cone HKS airfilter, Bigger HKS pipes to the Intercooler, And another ECU
Would it be around 400 hp ?
Toyota Supra TT ?96 BL 71GTS Single Turbo 54 k miles
BL 71GTS .81 A/R Turbo // HKS 264 Cams // Greddy 3-Row // PHR Stage 2 Fuel System(dual Walbro,Siemens 850cc Inj) // AEM EMS - 3.5 bar Map
SupraTT/Iceland is offline   Reply With Quote
Old 02-11-2006, 09:50 PM   #13
Do you mean 500hp or 500rwhp? Either way, yes...most of us run a blend of race gas, and/or meth/water injection, and/or toluene, etc. In general, it's either that, or keep the boost down... Besides, with a huge single turbo, 16psi makes more power than the oem twins do at that boost level. On the downside though, you have to deal with the lag of the huge turbo too...
...That is really expensive especially for a daily driven car.......and you have to take into consideration that the normal gas here costs 7 dollars a gallon .....it costs much more here then in Usa
What can I say, other than the well-known saying: 'you have to pay if you want to to play'. Besides, even if it cost you $20/gallon, a few gallons of race fuel is much cheaper than replacing a blown engine, right?
...But how many hp can I be expecting if i have the boost at 16 psi ? with a 3" inch HKS Turboback exhaust, Cone HKS airfilter, Bigger HKS pipes to the Intercooler, And another ECU
If you mean 400rwhp, then no...probably closer to 350rwhp...maybe 375rwhp (through a 6spd) on a cold day, if your engine is in excellent shape (i.e. good/high compression #s).
Old 02-11-2006, 10:52 PM   #14
SupraTT/Iceland
Hehe Thx for all the help Pwpanas i?ll just remember when i?m going over 16 psi I have to use over 100 octane gas. And never listen to the previous owner. damnit lieing to me that this was all safe I?m just so disappointed that the motor had only been driven 6000 miles
Old 02-12-2006, 02:14 AM   #15
I'm glad to be of assistance...and I'm sorry that the previous owner (i.e. a former Supra owner) gave you bad advice. Fwiw, I hope he was simply misinformed, and not intentionally misleading you to help sell his vehicle.
1991 Supra - Broken Front License Plate Screw unkymurch Non-Generation Specific Questions 1 01-08-2007 02:15 PM
