Old 06-19-2012, 07:37 PM   #1
fastsupra
fastsupra is on a distinguished road
Default Suspension
I am looking at getting a either just a good set of lowering springs or doing a shock and spring combo but I am not wanting to spend too much money on it.
I've heard that the Eibach springs are very good and the KYB shocks would be a good match to go with them. What are your takes on the springs and shocks? Also, how much of a difference will I feel handling and ride quality wise?
Thanks for the help!
fastsupra is offline   Reply With Quote
Old 06-26-2012, 01:27 AM   #2
1) Why do you want to lower your Supra? Please note that it may not handle better after being lowered.
2) N/A or TT?
3) Agreed - Eibach springs are quite good.
4) KYB/AGX shocks are a good aftermarket choice for the jza80.
5) The oem springs and shocks aren't really that bad either. In fact, they've been effectively roadraced in OLOA (Reg Reimer).
6) The shocks will make more of a difference than the springs in how the handling feels.
7) Consider aftermarket sway bars to further reduce body roll
Old 06-26-2012, 04:24 AM   #3
fastsupra
2) N/A or TT?
1) I want to lower it mainly for looks and to help with wheel hop
2) TT
3-6) Thanks for the info I think I will go with the kyb and eibach springs combo
7) What brand do you suggest going with?
Old 06-26-2012, 10:21 PM   #4
2) TT
1) The primary ways to reduce wheel hop are:
....A) Don't drag race with street tires or roadrace tires (i.e. use drag radials or slicks for drag racing), and
....B) Reduce (or eliminate) the play in the subframe bushings.
....Coilovers and/or shocks will have a near-zero impact on this issue.
7) TRD used to sell a good combo, but I don't think they're available anymore. I'd suggest these:
http://www.titanmotorsports.com/tmsadswbarfo.html
P.S. Fwiw, I honestly think a non-lowered Mkiv Supra Turbo looks just fine.
Old 06-27-2012, 05:33 PM   #5
fastsupra
Well I ended up ordering the BC Racing BR Coilovers because I want to lower my car a bit and up the handling all in one and I will also probley end up buying the TMS sway bars as well
Old 06-29-2012, 12:06 PM   #6
I haven't used BC Racing BR Coiloves before. Please post back and let us know how you like them.
Minor point: Above, where I asked why you want a springs/shocks upgrade, you didn't mention "up the handling". You just said:
If I knew you were also trying to "up the handling", I would have provided additional recommendations...
Old 07-11-2012, 07:34 PM   #7
fastsupra
Is there anything else that you would recommend to get along with the coilovers and sway bars?
Old 07-12-2012, 09:13 PM   #8
Have you considered wider rims and tires? Be sure to *at least* stay with the oem Z-rated rubber specs. At most, consider R-compound tires for serious roadracing, and either drag radials or slicks&skinnies for drag racing.
Also, find some correctly-sized flat washers to compress the subframe bushings. This will reduce the potentially-damaging effects of wheel hop if it occurs.
Tems suspension or no? bryanf89 MKIII Supra 52 03-22-2011 03:16 AM
i need help with suspension t12tninja MKIII Supra 2 10-14-2010 11:16 PM
HELP! Suspension Mods on 86.5 and 16" Tire Sizing Advice *FREE* dlfred MKIII Supra 1 05-16-2010 07:49 PM
Suspension rickvelezyr MKIV Supra 0 02-13-2010 06:32 PM
have some questions about 86-92 supra suspension jeremy_e87 Non-Generation Specific Questions 2 01-10-2007 11:53 PM
