Old 06-08-2012, 05:33 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by CarpeDiem View Post
Mark IV all-stock owner ('98), auto, have significant vibration at idle, worse at stop with foot on brake, goes away @~ 1100 RPM and otherwise engine purrs like a kitten (ok, maybe a mean one). Been to 3 different mechanics (incl Toyota dealership) and no one can fix it. FYI- I'm not a sophisticated car guy, but that's probably obvious!
1) TT or N/A?
2) Without being there in-person to troubleshoot, I'd suggest one of the likely culprits is a misfire...possibly due to an ignition issue. How old are your sparkplugs? Do you know what they're made of (copper, platinum, iridium, etc.)? How long since your last tune-up (and plug change)? How many miles on the car (and therefore the ignition system, coil(s), ignitor, etc.)?
3) Get/borrow/use a compression tester and post (or PM) the individual results for each cylinder.
http://www.mkiv.com/manual/manualtt/...eck/index.html
Life begins at 30psi.
Tags
vibration
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
High-Speed Vibration Jeff887 MKIII Supra 8 02-13-2009 09:21 AM
Nasty Tailshaft Vibration - Please Help! CNS45 MKIV Supra 2 12-22-2005 11:35 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
