Old 05-27-2013, 05:02 PM   #171
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default Need help making power 94tt
That is correct.That was on 1.5bar still with stock cooler.
warmkop is offline   Reply With Quote
Old 10-26-2013, 04:32 PM   #172
warmkop
Moderator
warmkop's Avatar
I everyone.
So update on the car is had trouble with the turbo leaking oil out in front and the back had the seals replaced on my new turbo and it was okay did like 2 events and a dyno and now the turbo is starting again o and it smokes between gears changes dont know why it keeps doing it.
But its in to get the luanch controll connected up and to set the boost up if the turbo is going to handle it.lol
Old 10-27-2013, 09:29 AM   #173
Originally Posted by warmkop View Post
I everyone.
A few questions:
1) Are you using 100% pure synthetic oil on all of your oil changes?
2) Do you have an oil filter installed in the oil line feeding the turbo?
3) Do you have a restrictor installed in the oil line feeding the turbo? (Note that HKS turbos come with a restrictor built into the oil line fitting on the top of the turbo.
http://www.turbobygarrett.com/turbob...oil_restrictor
Old 10-27-2013, 05:40 PM   #174
warmkop
Moderator
warmkop's Avatar
I just changed the oil it had synthetic oil in changed it to semi synthetic because I change the oil about every 3 months.
No I don't have a filter.
It has a 3mm restrictor in.
Old 10-31-2013, 06:58 PM   #175
Recommend you change back to full synthetic. The temperature of your turbo(s) break down non-synthetic oil, no matter how often you change it.
3mm is quite large - you may wish to consider a smaller diameter restrictor and an oil filter in your turbo's oil feed line. The smaller restrictor may fix your turbo oil seal leaks, and the filter will help keep the restrictor from getting blocked by random debris (or particles of coked non-synthetic oil) that may end up in your crankcase. This restrictor has a .04" (1.016 mm) oil passage:
http://www.frsport.com/Turbo-Oil-Res...FQto7Aod-iwA-w
A 1mm restriction has 0.785 sq. mm. area, and a 3mm restriction has a 7.065 sq. mm area (9 times greater). Although I'm not a fluid dynamics engineer, I'm sure a hole that's 9 times bigger will flow quite a bit more oil...
Old 11-05-2013, 08:46 PM   #176
warmkop
Moderator
warmkop's Avatar
I need advise on launch control we can't get the chip to read the crank signal black/red wire any advise..
Old 11-06-2013, 11:20 AM   #177
I assume everything is running fine other than the launch control.
Are you using the oem crank signal, or have you equipped the harmonic dampener with a secondary (eg. hall effect) magnet & sensor?
Old 11-06-2013, 04:56 PM   #178
warmkop
Moderator
warmkop's Avatar
Everything is running fine.
Using oem crank signal.
Old 11-10-2013, 12:29 PM   #179
If your aftermarket traction control system can't read the oem 2jz-gte crank signal, you may need to use an aftermarket crank signal.
When I was running my Haltech E6K, this was a required modification.
Check out the link in my last post (above), and let me know if you have any questions.
Old 12-08-2013, 08:45 AM   #180
warmkop
Moderator
warmkop's Avatar
Yes I agree but if I do the aftermarket crank signal how do I do the timing how will the stock ecu read the signal and how do I cut the timing for the launch controll
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
