Old 03-24-2011, 09:54 PM   #1
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default need help making power 94tt
Hi im from south africa bought a 94tt supra not many here this side need help making power out of my dream car. bougt a godspeed branch t4 need to know what exhaust housing wil work dont whant to much lag so 4000rpm is fine.busy with atermarket ecu,extra feul pump at least 23 psi with racing feul any comments welcome
warmkop is offline   Reply With Quote
Old 03-25-2011, 12:32 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Gosh...here's my advice (for now). Please slow down! One step at a time! Please do not get the fuel kit yet. Please do not invest in the aftermarket ecu yet. Let's come up with a plan that matches your horsepower level...if you want power at 4000 rpm, most likely the turbo will be small enough to work fine with the oem ecu. Also, any turbo with its max efficiency point at 23psi will be moderate sized at most. The Mkiv TT is an amazing, very upgradeable vehicle - and a lot of the stock parts are good to MUCH more than the oem rating. Ok?
Who is telling you to do all of these crazy things right now?
Where can I find specs on the "godspeed branch T4"?
Life begins at 30psi.
Old 03-25-2011, 03:42 PM   #3
warmkop
Moderator
warmkop's Avatar
bought the branch on ebay. previouse owner fiddle with the twin turbo system and is giving me problems.whant to get the most power out of the enjin stock.already have the aftermarket management gotech pro x.not sure how much boost the stock motor can handle ive read it is alot.im not sure what size turbo to use a/r dont whant to buy to big and have to much lag dont want to use nos. will a ar86 twinscroll exhaust be to big.
Old 03-26-2011, 03:56 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
The stock engine can take a LOT of boost, but only on race fuel (and/or alcohol injection). What is the octane of fuel you have available? Also, please provide the formula used to calculate the octane (RON, MON, R+M/2?, etc.)
Turbos aren't primarly rated in AR...they're rated in inducer size (eg. 58mm, 66mm, 71mm, 76mm, etc.). Please get me more info on the system(s) you're considering.
Old 03-26-2011, 11:12 PM   #5
warmkop
Moderator
warmkop's Avatar
Default need help making power 94tt turbo sizes
il start of with afgas 100/115 LL it has 0.3 TEL dont know much more ,first will use stock injectors and see how much boost i can get. later stage want to use e85 ethanol.this sizes apparently is for 450-600 hp turbo that is all they say.Does the sizes look rite or not
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 66.71 /84.20
Turbine wheel diameter : 63.56 /73.60
Exhaust trim: 1.00ar
Old 03-26-2011, 11:41 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Intake :4 inch
Outlet: 2.5 inch
1) You have what's usually referred to as a 67mm turbo. This is considered an approximate 700rwhp turbo through a 6spd.
2) This turbo will outflow the stock injectors, so running it without an upgraded fuel kit is dangerous. If for some reason your boost control fails, your air outflows your fuel, and melted pistons result (even with race fuel or aviation fuel). You need to get rid of the oem fuel system immediately. Your new fuel system should use at least 780cc (75#) injectors.
3) Boost is not determined by the fuel, it's determined by your turbo and your fuel controller. If you block off your wastegate (or modify the boost controller to achieve the equivalent) your turbo is capable of well over 35psi of sustained boost... However, don't run it that high! You must use your boost controller to ensure that you do not run more boost than the octane of your fuel can support.
4) Are you running an auto or a 6spd?
5) I believe that the exhaust a/r on this turbo is inappropriate for your application (too large). Ask your supplier if you can replace it for a smaller exhaust housing (eg. .80 a/r)
6) The compressor housing outlet is a bit small. See if you can get it replaced with a housing that has a 3" outlet.
7) Which intercooler are you planning to use?
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
