Old 03-06-2011, 02:41 AM   #21
2JZDU
2JZDU is on a distinguished road
One of the two codes appears to be 14, right?. Let's start with that:
14
Ignition Signal
No IGF signal to ECM for 4~7 consecutive IGT signals with engine speed less than 3,000 rpm.
  • Open or short in IGF circuit from igniter to ECM
  • Igniter
  • ECM
ONn/a
Yes
It seems you may have a problem with your igniter. Did you ever get a TSRM for your Supra?
Also, please re-check those codes. I don't think it's possible for the ecm to give a single-digit code. Perhaps it's 22?
hi mate, but if it's code 22, should the time gap of those flash a bit longer? I did upload to youtube, would you mindhave a quick look for me?
http://www.youtube.com/watch?v=k7V4UdBdpZw
many thanks
2JZDU is offline   Reply With Quote
Old 03-06-2011, 12:17 PM   #22
pwpanas
Supra Owner
pwpanas's Avatar
many thanks
To me, it looks like codes 14, 21, and 42. Can you continue the video longer? There is a HUGE pause when the cycle of codes ends...
Life begins at 30psi.
Old 03-13-2011, 11:52 AM   #23
2JZDU
hi mate, I have replaced an good working igniter, but the code 14 is still there, and I have take a longer vedio this time but I got two code of 42, it almost drives me crazy ......
http://www.youtube.com/watch?v=D5tlmKcrUZA
Old 03-13-2011, 04:37 PM   #24
pwpanas
Supra Owner
pwpanas's Avatar
Yep it's codes 14 and 42 for sure. The TSRM will help you to diagnose each code. This isn't 'rocket science' or voodoo. Each code has a series of troubleshooting steps, detailed in the TSRM, that will always resolve the code. Think of it this way - even a high-school graduate Toyota mechanic has to be able to follow the instructions! No slam against high school grads at all - I often wish I had a job that let me get outdoors or get some exercise during the day instead of being stuck behind a desk.
14 is your "Ingition Signal" (not necessarily your igniter). It could also be an open or short in the circuit, or a problem with the ECM itself. You'll likely have to diagnose the problem with a multimeter.
...and 42 is a problem with your "No. 1 Vehicle Speed Sensor" (or the electrical connection to it from the ecu). Replace the sensor and/or troubleshoot the wiring with a multimeter.
Again, get the TSRM!!! It'll save you time and $$$. Really!
Old 03-30-2011, 12:37 PM   #25
2JZDU
finally fixed the problem.
it casued by the starter...but the car give me a code 14..
anyway.. thank you everyone
Old 03-31-2011, 11:16 AM   #26
pwpanas
Supra Owner
pwpanas's Avatar
Thank you for posting back with your result, and congratulations on solving the problem!
Old 09-14-2011, 02:04 AM   #27
nbbruch
nbbruch is on a distinguished road
Default Same thing on 1993 supra TT
Im getting codes 14 and 42 also. Car goes into safe mode and runs but with no power and misses awful if u step on the gas to much. You say you replaced the starter?????????????? and that fixed it? please confirm this for me as I can get to work on that. Thanks
nbbruch is offline   Reply With Quote
Old 09-19-2011, 03:39 AM   #28
pwpanas
Supra Owner
pwpanas's Avatar
You probably have a boost leak.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
check engine light Clorox9 Non-Generation Specific Questions 1 05-08-2009 06:57 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
