Old 03-26-2008, 02:45 AM   #1
marmlr339
marmlr339 is on a distinguished road
Cool possible power output for tuning a non-turbo supra
this is, without installing a turbo. i can't do that because i legally can't drive turbo cars, until im off my p's at age 20. 18 now, but looking at a non-turbo model. also i can't exceed 200kw's (280hp). i know they are stock about 160, what would get me to 190's? and also, when i'm 20, could i add a turbo and get about 400 / 450hp (300 - 350kw) without buying a new car, and would it be safe, as i know non turbo engines are different from turbo engines? thanx
marmlr339 is offline   Reply With Quote
Old 03-26-2008, 01:12 PM   #2
Twin Turbo '95
Twin Turbo '95 is on a distinguished road
you could change your cams. larger injectors. different ecu. decat. 2-2-4 branch. could get your power up to close to 200hp.. it depends on how much you are willing to spend
Twin Turbo '95 is offline   Reply With Quote
Old 03-27-2008, 01:39 AM   #3
marmlr339
close to 200hp? they have OVER 200hp stock. or do you mean 200extra horsepower? im confused. anyway they have about 160kw stock, which is about 220hp, so that woud reduce power? and i can't go turbo until i turn 20, which is a shame. i haver the money required for a MKIV supra, and a few grand for extra's, but i just can't go turbo, or exceed 200kw (about 250hp)
and would it really be necessary to upgrade the cams? don't they last until about 500hp anyway? and the ecu. do you know anything about the cost of that? couple of grand, right?
Old 03-27-2008, 06:48 AM   #4
Twin Turbo '95
oops. sorry. close to 200kw. better?
fitting a bigger cam means there is more time for air to get into the combustion chamber. more air=more power. just to see if i have the once sentence right.. only upgrade a ecu when your close to 500hp?? you can change the ecu on a stock car. they can map it in the way you want. performance or fuel consumption. your building a n/a car. so you need to get power from any place you can. n/a cars are more expensive to get to the same power as turbo cars. but they say in the end when you do get there.. it was all worth it.. but i dont know about that. im a turbo person. with a little hint of nos
Old 03-27-2008, 11:33 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Honestly, the sky's the limit. Anything you can do with turbocharging (or supercharging), you can also do with nitrous. Note however that large 'shots' of nitrous are a bit trickier to tune for, since both timing and air/fuel have to be adjusted in concert. Note that, just as with na-t turbo kits running a higher amount of boost, you'll need to run a thicker headgasket and/or change your pistons.
Life begins at 30psi.
Old 03-27-2008, 12:09 PM   #6
Twin Turbo '95
to make more power.. yes. different components in the engine do different things. you can have as much power as you want. but if you cant get any air into the engine. what does all the power help you.. changing the cams will help get the air better into the car. see where im going with this?
Old 03-28-2008, 04:28 AM   #7
pwpanas
Supra Owner
pwpanas's Avatar
...and would it really be necessary to upgrade the cams? don't they last until about 500hp anyway? and the ecu. do you know anything about the cost of that? couple of grand, right?
I have no idea about the 2jz-ge (non-turbo). The us-spec 2jz-gte can make over 700rwhp with the oem cams.
Old 03-28-2008, 03:37 PM   #8
Twin Turbo '95
how big is the oem cams? 268?
Old 03-29-2008, 01:41 AM   #9
suprasath
suprasath is on a distinguished road
hey man just do the smart thing. dont waste money on a n/a. wait 2 years, itll just fly by. your just young and excited. buy and mkiv or get a turbo engine. then you got a nice power plant under the hood
suprasath is offline   Reply With Quote
Old 03-29-2008, 04:21 AM   #10
pwpanas
Supra Owner
pwpanas's Avatar
They're closer to 248s (perhaps even as small as 242s), which is still plenty large enough when you're dealing with forced induction and very high cylinder pressures (compared with an n/a engine).
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
1000hp here i come disturbednitehawk Shops & Part Reviews 36 07-28-2006 02:30 AM
Power FC for Jap spec 1999 Supra Turbo? JZA80-1999 Shops & Part Reviews 0 01-03-2006 05:33 PM
