Old 10-19-2007, 01:17 AM   #1
tone loc
tone loc's Avatar
Default what size mhg??
-.004 on the head and -.003 to -.005 on the block. what size should i get and whats the best brand?
Old 10-22-2007, 09:00 PM   #2
tone loc
tone loc's Avatar
bump can someone give me a hand?
Old 10-23-2007, 01:51 AM   #3
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
1.2mm should still be fine unless you want a thicker one like the 2mm. i've used the cometic and hks, they both work the same and are metal. but the hks is more expensive than the cometic
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 10-23-2007, 02:42 AM   #4
tone loc
tone loc's Avatar
what are the effects between the 1.2mm and 2mm on the engine?
Old 10-23-2007, 02:53 AM   #5
kwnate
It will effect your compression ratio, the thicker the hg the better (lower compression) if you're running higher boost
Nate
Optimal Size JPDsupra MKIV Supra 1 06-30-2007 12:39 PM
bolt size? west_side_supra MKIII Supra 5 04-08-2007 06:18 PM
Whats the best catylac converter size 88Tsupra MKIII Supra 6 02-09-2007 07:58 AM
