Old 10-10-2007, 09:30 PM   #1
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Default No Spark From Coil
Hey, i bought a supra '92 with a 5M GE engine, we cleaned out the injectors because it was smoking black, afterwards it was running well but suddenly the engine shut off and we had to push it back after checking it was the coil that does give sometimes spark when you move the coil but without touching it it will not any tips or reasons for this problem?
SilenceboneSupra is offline   Reply With Quote
Old 10-10-2007, 09:58 PM   #2
dcrusupra
dcrusupra's Avatar
Is it an 82 or a 92? I've never heard of a 92 with a 5M-GE. Is the ground connected on the coil?
New Rebuild
My CarDomain
Old 10-10-2007, 10:03 PM   #3
SilenceboneSupra
it is a 5M GE engine it was purchased and put in a '92 supra
Old 10-10-2007, 10:08 PM   #4
dcrusupra
dcrusupra's Avatar
Never seen that swap before. Care to post a few pictures of it? And it could be a bad ground on the coil or it could be a dead coil itself. When you move it, something could connect inside that has previously let go.
New Rebuild
My CarDomain
Old 10-10-2007, 10:12 PM   #5
SilenceboneSupra
yea strange swap it has not sow much room under the hood with this engine, i currently do not have pictures but the car was running well with this engine i bought it from someone the only problem was the clutch sow had that replaced and it was running well with no problems at all untill the problem with the coil. the coil is not giving any sparks on itself only when you move it around or hit it softly with something...
Old 10-11-2007, 02:20 AM   #6
mrnickleye
mrnickleye's Avatar
Wink
Sooooo.......what part are you gonna replace????????????
Old 10-11-2007, 04:12 AM   #7
SilenceboneSupra
IDK why should i replace the coil if it is working? it is not giving any sparks on itself only when you move it or hit it softly
Old 10-11-2007, 01:50 PM   #8
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
iom having a similar problem myself i was driving and i was low on gas and my7 car died it was running but when i pushed my gas down it didnt go anywhere it wouldnt move then about 6 seconds later my car died i tryed startng it while rolling at 45 and then i just coasted into a gas station. got gas and it still didnt start. i kept trying it and it finnally started and i drove it home turned it off to go get my books for college and when i came back out it didnt start whatso ever and now im driving my blue truck around. my starters turning over and i have fuel pressure on my areomotive fuel pressure regulator and i think that either my fuel filter is clogged and i have never replaced it so im def gonna try that and if not then i have 2 more coil packs and ill try replacing it. im gonna diagnose the problem this afdternoon so ill give you the word and let you know. plus i would very much like to see this 5mge please take pictures. i dont get why they did that switch. i would of just redid the headgasket on the 7mgte with new headbolts and boosted it up to 17. and that 5mge wouldnt of been able to touch it. or they blew the engine and thats all the money they had was for a 5mge. keep in touch
Live life and kick ass
Travis
1989 toyota supra, 7mgte boosted
tsupra89 is offline   Reply With Quote
Old 10-11-2007, 02:59 PM   #9
SilenceboneSupra
i have been told that the engine it had was taken out for replacing the parts but got stolen
Old 10-11-2007, 04:43 PM   #10
SilenceboneSupra
let me change that it is indeed a 7MGE motor just a wrong logo on it, i have checked with the previous owner and it is a 7MGE engine
88 N/A Manual, No Spark! supraman8188 MKIII Supra 5 06-30-2010 03:38 AM
No spark mystery on 7mgte jcgrant4 MKIII Supra 9 08-19-2009 06:21 PM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
