#1 |
idk im ganna try to adjust it again or sumthing, im ready to call it wuits and take it to a shop
![]() nothing but the best -mods- so far K&N intake fipk 3" megan downpipe 3"turbo elbow 4 washers on the wastegate highflow cat short shifter 89+ front bumper, pic soon to come many more upgrades soon |
#2 |
idk any more i replaced the tps and thought i had reset it right, but i baught i used one with a new throttle body but its still doing the same thing...im ganna buy a new tps and see if thats it..and if its not..im giving up and either takin it to a shop or selling it
#3 |
7M POWAH! ;)
you're hitting fuel cut very early, does it blow alot of black smoke out the exhaust? how does it idle?
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#4 |
When I had to adjust my TPS a short while back I found that using a hacksaw blade was a good thickness to put between the throttle and stopper. Then using the Ohm meter setting the TPS to any reading that wasn't 0 or 1. NOTE: It was hard for me to get it to the specs according to my Toyota OEM repair manual. But the car drives better now. Maybe do that simple test to see if your TPS is causing the fuel cut. I was ready to buy a new TPS too...but I'm sure like mine yours is still okay. I'm running on 250,000+ miles.
#5 |
it idles fine, at liek a little more than 700rpm..i dont notice any exxesive gasses out of the exhaust..can any1 take a picture of their tps so i can see where theirs is set at? im tryin this whole ohm meter thing tommorow again but i can never get it to spec. and also on one of the fuel lines there seems to be gasoline comming out, but only a microscopic amount, just enought to get the surface of the fuel rail a tinnnnny bit wet, but i dont think thats the cause, its from a bad brass washer on the bottom of it. but idk a pic of sum1 tps wuld help please
#6 |
ok honstly fuck this car....ive tried to set the tps in every spot, and it just doesnt work...still has the same damn problem with fuel cut around 2k rpm....im readin the tsrm and no matter where i put it the numbers on the ohm meter never change when i move the tps, they always stay at like 6.09k ohm i really feel like blowing this P.O.S. up
#7 |
VC to E2 should be the same no matter what you do to it.
VTA to E2 is the one that steadily climbs in resistance as you increase the TPS to wide open throttle. IDL to E2 should read an open circuit as you just open the throttle from closed fully closed. If you look at the picture in the TSRM you should be using the second one down. The TPS is mounted 180 degrees out between the NA and the Turbo so the terminals will be reversed. If your reading it mounted on the throttle body and reading the terminals like its an NA then your readings will be off. Also make sure you aren't touching more than one terminal with one lead. Using alligator clips helps in this case. For the proper adjustment with a feeler guage use the measurements in the TSRM when its mounted to the throttle body. Im looking at page FI-100 and FI-101 |
#8 |
![]() Thats what mine looks like, its never been removed from my throttle body before. You see that yellow paint mark? That's from the factory. What terminals are you using when you adjust the sensor? |
#9 |
idk then, im beggining to think its not my tps, bt im gettin the code 41 so idk. im just ganna take it to my auto shop at school and have my auto teacher do it
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine Problem | Stymee14 | MKII Supra | 2 | 08-06-2007 02:17 PM |
| 83 ECU on a 82 | Cowardsrus | MKII Supra | 3 | 05-29-2007 06:46 PM |
| Auto to Manual transmission? | dannydavi | MKIII Supra | 19 | 05-18-2007 05:33 AM |
| 89 supra. lots of problems.. HELP!! | 89_supra_ | MKIII Supra | 9 | 12-15-2006 02:28 AM |
| painting my grill? | newbsupra | MKIII Supra | 18 | 09-03-2006 12:55 AM |
