Old 05-26-2007, 06:34 PM   #1
supraman121
Default Tri angle valve jobs
I heard that this will increase the power of the stock engine for relatively cheap? i was woundering if anyone has had this done, how much it cost, and what the horsepower gain was?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 05-27-2007, 01:19 AM   #2
mattfurlani
mattfurlani is on a distinguished road
I've never done it personally, but a 3avj is definately been proven to increase performance.
It might not be worth the money though.
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
mattfurlani is offline   Reply With Quote
Old 05-27-2007, 04:40 AM   #3
supraman121
i was told it was relitavly inexpensive, do you know how it is done? do you have to completly remove the valve or can they get to them without taken the engine apart?
K&N Air Filter
Old 05-29-2007, 03:03 PM   #4
mattfurlani
uh well you have to shave the valve seat in three seperate angles. I think it is 31/46/60 and i cna't particularly remembver if you need to take everything apart but just imagine remmoving your head from your car.
That's how much work it is.
so fdor a supra its romving intake, cooling system, exhaust, and many things like egr, vsv's, and a buncha other things i can't ermember.
almost everything but the block. a good 10 hours of labor with the right tools and know how
then its like $200 to havfe it angles done at a machine shop... a good priced shop at that.
Old 05-29-2007, 07:54 PM   #5
Kuban
Kuban is on a distinguished road
yea and lets not forget you should pull your block out and have it decked while your at it. Its only an extra day of labor. You mine as well spend 500 at a machine shop and have them port, polish, and do a valve job.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Old 05-29-2007, 08:19 PM   #6
supramacist
supramacist's Avatar
Yep. Just sac up and get the p&p.
If you don't you'll just end up wishing you had.
Old 05-30-2007, 06:16 AM   #7
supraman121
screw trying to get power out of an NA motor i need to find some place that sells 7mgte front clips or 1jz front clips then i would be in heaven lol
K&N Air Filter
Bad Proportioning Valve? georides Non-Generation Specific Questions 5 03-05-2009 03:34 AM
valve cover gasket question? sevenmgte MKIII Supra 8 10-01-2008 06:02 AM
88 Turbo Leaking Valve Cover Gaskets Sheridan MKIII Supra 1 11-05-2007 01:03 AM
egr valve... reusable? sd88supra MKIII Supra 3 06-22-2007 06:28 AM
Valve stem seals? Kuban MKIII Supra 9 03-27-2007 02:32 AM
