Old 05-06-2007, 06:39 PM   #1
D r E E z y
D r E E z y is on a distinguished road
Default i got some problems 88 non turnbo
when i start my car the rpm jums up and down, until it gets lower and just shuts off. anyone know what the problem is? the check engine light isnt on or anything.
D r E E z y is offline   Reply With Quote
Old 05-07-2007, 03:35 AM   #2
OfnaRcR
Check a pipe that comes out of the intake manifold toward the firewall. I think its called the EGR?
Old 05-07-2007, 03:03 PM   #3
Kuban
Alot of things can cause an idle surge. Look in the tsrm and see what it lists for idle surge.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Old 05-08-2007, 11:59 AM   #4
f00g00
Default Tps
Check your Throttle position sensor on the throttle body cause its probably hosed. Its in the TSRM how to do this. Ive had the problem at least 3 times in 8 years with my supra and its allways been a bad TPS. I don't have an EGR valve so I can't vouch for those.
Old 05-09-2007, 07:50 PM   #5
west_side_supra
west_side_supra's Avatar
hmm when my rpms where jumpin around, it was because of the wires for the CPS and the coil pack harness wires where melted.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 05-09-2007, 09:46 PM   #6
supramacist
supramacist's Avatar
what's a turnbo???
Old 05-09-2007, 11:25 PM   #7
west_side_supra
hmm wait them non turbo supras have distributors dont they, my bad oh well.
fidenza cam gears
Old 05-10-2007, 12:09 AM   #8
supramacist
Yes..., we have distributors, caps and rotors.
Some of us even have MSD.
Distributor problems? ekoston69 MKIII Supra 1 02-02-2006 11:29 PM
