Old 05-06-2007, 08:27 PM   #11
west_side_supra
west_side_supra's Avatar
Originally Posted by west_side_supra
2nd run shitty RT again was racing a undercover cop car ran a 13.443
oh if you where asking about the undercover cop yea, i beat it, silly crown victorias.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 05-06-2007, 11:27 PM   #12
kwnate
SP58GT
I don't believe you ran an 11, or a 13.3 with the mods you listed. What was your 60' time and your trap speed on all your runs.
Nate
Old 05-07-2007, 03:32 AM   #13
supramacist
supramacist's Avatar
Damn..., call a brother out.
Old 05-07-2007, 07:50 AM   #14
west_side_supra
ok lets see here
1st run
dial...
r/t... .697
60'... 2.297
330 ... 5.256
1/8 ... .000 < id didnt read it for some reason
MPH ? same deal
1000' 12.273
1/4 ... 14.614
MPH ... 96.77
2nd run
dial ...
r/t .721
60' ... 1.761
330 .. 5.405
1/8 ... 8.547
mph ... 80.02
1000 ... 11.332
1/4 ... 13.443
mph ... 101.10
3rd run
dial ... 13.50
r/t ... .453
60' ... 1.483
330 ... 4.742
1/8 ... 7.639
mph ... 83.42
1000 ... 9.332
1/4 ... 11.326
mph ... 97.10 mph
you dont have to believe me but i swear to god i aint bull shittin you, my best guess is for the 11sec run was that the test pipe busted on me so it was runnin right off the 3inch dp. the turbo was hittin fuel cut the 2nd run. thats probably why it came to a 13, then rule that with the shitty r/t, and also the 3rd run i warmed them tires up. but ill try to find a way to get these time sheets or photo taken i dont know ill find something so you guys will believe me
fidenza cam gears
Old 05-07-2007, 08:41 AM   #15
west_side_supra
ok so i took a picture of it with my phone, sorry the quality sucks but you can at least make out the numbers on it. so untill i get a working scanner this is the best i can bring you for now.
fidenza cam gears
Old 05-07-2007, 03:49 PM   #16
kwnate
SP58GT
With a 5speed car, you'll need 550-600rwhp to run a 11.3 and a 1.7ish 60' You should be trapping around 125mph at that time.
Nate
Old 05-07-2007, 05:00 PM   #17
IHateHacks
IHateHacks's Avatar
I agree with kwnate, your trap speeds are far too low to be running 11's, that is, unless you slammed on the brakes at the end.
I think its just a typographical error on the timeslip, there really is no way you can be running 11's with just an open downpipe, 12psi of boost and a clutch on a stock 7M.
The first run is spot on though with a stock MK3, they run high 14's stock.
Old 05-07-2007, 05:05 PM   #18
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
who is this snowman.... im calling bullshit..
Supra_87_mk3 is offline   Reply With Quote
Old 05-07-2007, 06:42 PM   #19
upgradedsupra
upgradedsupra's Avatar
upgradedsupra is on a distinguished road
This is a bullshit timeslip and probably domeone elses.
To do an 11.3 ish, you need at LEAST a 100 MPH trap in the 1/8 or close to it and hitting 97 in the 1/4? HAHAHAHA > that is a 13.7 or there around. Ask me how I know
My 89 Supra, I ran 11.0@130 trap > 1/8 mile trap was 103.MPH and in a 3600 car (weight reduction as well) This was when I had 620 RWHP 60ft was 1.68
Brothers RHD Supra I ran a 13.7@99MPH (with SLICKS I might add)
The ONLY way to believe that time would be IF you had a video but that would prove that you did a 14.
Duane
GT4202, MoTeC, 7M powered.
(update) Best 1/4 mile 9.9@147 on and off the throttle.
upgradedsupra is offline   Reply With Quote
Old 05-07-2007, 07:32 PM   #20
west_side_supra
ok so i looked at the numbers a little more, look at the number diffrences between the 2nd and 3rd run, add it up, the diffrences would come out do about a 2 second diffrence for the final time.
fidenza cam gears
1989 MKIII Build...Wish me Luck and HELP!! BoostedOne MKIII Supra 3 02-12-2009 03:02 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
do luck middle support bar?? stiffin er up joel w MKIII Supra 1 11-09-2005 03:07 PM
Fuzzy logic boost controller... HELP. smurfmods MKIII Supra 7 10-08-2005 09:39 AM
