Old 04-09-2007, 05:34 PM   #11
IHateHacks
IHateHacks's Avatar
No, first install that timing belt the way it should be. Then, set base ignition timing. After you do these 2 things you will be able to diagnose your problem further.
Instead of throwing parts at your car you should have tested your coils with a multimeter.
Old 04-17-2007, 09:32 PM   #12
west_side_supra
west_side_supra's Avatar
here is a video of me 3rd gear the CEL is on and want you to attempt to listen to the engine, and notice how much the camera is shaking that would be the car shaking the shit outa me, i had the gas completly to the floor.
video
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-18-2007, 01:23 AM   #13
west_side_supra
this could acually be the end to this thread, mmm i took a closer inspection and the wires that hook to the coil packs at the bottom, i took all of the old electrical tape off and found that 2 wires where either melted or chopped a little and where barley hanging on, so i fixed it drove it and no CEL drove fine so im now going to see about getting a new fuel filter and get the timeing done.
now for a quick question on the thermostat houseing there are 3 connectors on it, the one with the 2 little hoses comeing off of it, a green thing with a wire comeing off it of, and at the bottom there is a blue one with a wire.
what is the blue one? cold start?
fidenza cam gears
Old 04-18-2007, 01:30 AM   #14
IHateHacks
IHateHacks's Avatar
The blue one on the bottom is the auxiliary fan sensor switch.
The one in the middle (mine isn't green) is the A/C coolant temp sensor.
The one on top is the BVSV. Bimetallic Vacuum Switching Valve.
The cold start injector time switch is on the water outlet housing, its the one on top with the brown connector. The water outlet housing is what the thermostat housing bolts to. Then from there the middle one on the water outlet housing with the green connector is the ECT sensor (Engine Coolant Temperature for the EFI). Then the one on the bottom of the water outlet housing is the sensor for the stock temp gauge on the dash.
Old 04-18-2007, 01:33 AM   #15
west_side_supra
hmm do i need the blue one connected because its hanging on 1 little wire to, needs to be redone.
fidenza cam gears
Old 04-18-2007, 01:36 AM   #16
IHateHacks
IHateHacks's Avatar
If you want your aux. fan to work then you need it.
Old 04-18-2007, 01:41 AM   #17
west_side_supra
is the aux fan that little fan on the radiator, whats the point of it?
fidenza cam gears
Old 04-18-2007, 01:47 AM   #18
IHateHacks
IHateHacks's Avatar
Its the little electric one near the battery. It comes on when the coolant temp gets to a predetermined temperature.
The only time mine came on is when I had a BHG and my motor was overheating. My coolant temp was 230F when it was on. Mine hasn't come on since the rebuild. Then again my coolant never gets hotter than 195F. If I had to guess, it comes on at 212F.
Old 04-19-2007, 10:28 PM   #19
west_side_supra
haha well my car was just playing with me, im still getting the codes again
here is a video of my car warmed up completly and sitting at idle
http://s40.photobucket.com/albums/e2...nt=lowidle.flv
and here is a video of me holding at RPMS its hard to hear but you can hear the popping of what sounds to be back fireing. just there very quite.
http://s40.photobucket.com/albums/e2...holdingRPM.flv
i have not offically gotten completly lost in this problem.
fidenza cam gears
Old 04-20-2007, 01:51 AM   #20
IHateHacks
IHateHacks's Avatar
Have you reinstalled that timing belt the way its suppost to be? No.......
Have you set base ignition timing after you reinstalled the timing belt the right way? No............
I can guarantee that is your problem. Or one of them.
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
Code 12 808Supra MKIII Supra 3 05-20-2007 09:55 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
