Old 03-20-2007, 01:33 AM   #1
burton51m
burton51m's Avatar
Default oxygen sensor
my engine light came on when i was driving down the highway yesterday. I did a diagnostic check when i came back and got a code 21 (oxygen sensor signal).
It could be the oxygen sensor itself or the wiring, ( Checked all the connections..no loose wires or dry rotting here)I dont know yet.
any way of telling?
any way of cleaning the sensor? Because a new one if really expensive.
Old 03-20-2007, 01:38 AM   #2
No cleaning, only replacing.
They aren't too much $$$.
If wiring seems good, then likely sensor.
Ohm meter testing, or best is 'on the car' with proper scanner.
Old 03-20-2007, 09:47 PM   #3
burton51m
burton51m's Avatar
i thought the guy said they were $146.** at the dealership when i called?
at least i think he said $146
Old 03-20-2007, 10:56 PM   #4
redmaro
I you dont want to spend that much look into Bosch O2 sensors, they are cheaper . You can buy them at Auto Zone or Checkers.
MK3, Auto, Turbo.
Old 03-21-2007, 02:28 PM   #5
Staceman
Staceman is on a distinguished road
Don't go with Bosch. You can get NipponDenso o2 sensors at sparkplugs.com far cheaper than the dealer. This is OEM. Also, the "snout" is longer than the Bosch, which gets a better read of the exhaust as it passes through. Check it out.
Staceman is offline   Reply With Quote
Old 03-22-2007, 02:50 AM   #6
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
I bought one and found out later I didnt need it. $50+ shipping and its yours.
OmeGa is offline   Reply With Quote
Old 03-23-2007, 03:11 AM   #7
burton51m
burton51m's Avatar
i already got one at autozone for 40 thanks anyway
Old 03-25-2007, 08:16 PM   #8
ethan12510
ethan12510 is on a distinguished road
Default Where?
my 89 supra also needs a new o2 sensor. but where exactly is the o2 sensor loacted? Thanks.
ethan12510 is offline   Reply With Quote
Old 03-25-2007, 08:21 PM   #9
redmaro
Its located right on the Turby elbow.
MK3, Auto, Turbo.
Old 03-25-2007, 08:24 PM   #10
ethan12510
im sorry but im a bit of a noob. And Dont know what a Turby elbow is. sorry
And thanks in advance for the help!!
oxygen sensor 82 supra amigo MKII Supra 0 12-13-2008 03:28 PM
Oxygen sensor -wideband or narrowband? azerty MKIII Supra 1 05-06-2008 01:48 PM
oxygen sensor suprakid91 MKIII Supra 3 10-21-2007 04:41 PM
sub oxygen sensor sd88supra MKIII Supra 4 04-13-2007 01:20 PM
Oxygen Sensor questions RyDeFly MKIII Supra 14 02-11-2006 01:41 AM
