Old 03-18-2007, 03:03 PM   #1
Kckazdude
Kckazdude is on a distinguished road
Default Need suggestions
The car is a 88 N/A auto. The porblem is when the car is running, when exiting vehicle you get a nice static discharge. I have replaced plug wires, battery grounds added engine ground wires. Nothing is alleviating this issue. What else am I missing that may cause this? Obviously it is a ground issue. I just havent figured out the proper ground problem.
Just to clarify, this isnt a full on ignition wire shock. I get one fair discharge and no more until I touch metal again a few minutes later. If the car isnt running or is never started you dont get shocked. If standing outside the car, it needs to be running for a few minutes before you will get the discharge.
'88 Supra, N/A, Auto.
Kckazdude is offline   Reply With Quote
Old 03-20-2007, 04:49 PM   #2
f00g00
I have a similar problem but I allways attributed it to the velvety seat covers
which will produce static electricity if wearing polyester or nylon clothes, I also have a sunroof and the headliner is some sort of material that also makes my hair stand up if my seat is adjusted too high.
I would bet the Supra owners with leather don't have this problem.
Old 03-20-2007, 09:41 PM   #3
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
i have only had leather interior supras and have never gotten shocked. i really don't know what to tell you on how to fix it sorry.
justin1642 is offline   Reply With Quote
Old 03-20-2007, 11:00 PM   #4
Cjanik
Cjanik is on a distinguished road
not something you can really "fix"
static electricity will always be there.
when you get out, you have two choices:
1) hold the frame as you get out of the car, that will ground you to the frame thus preventing a static discharge.
2) get out of the car with your key in your hand, and then touch the key on the door frame before you close the door.
Cjanik is offline   Reply With Quote
Old 03-20-2007, 11:13 PM   #5
Kckazdude
It is more than just a static discharge. Dont even have to be in the car to get shocked. Just walk up to it after it has run for more than 5 minutes. The whole thing it has to be running for it to happen. If/when I get to the bottom of this I will report back what I finaly discovered.
Old 03-21-2007, 01:01 AM   #6
dannydavi
dannydavi's Avatar
same thing is happening to mine, not only is it weird and annoying... but it almost broke skin once. It's quite a large electircal discharge. im very interested in seeing what you come up with... cause i was ready to start replacing the things you had mentioned and it didnt help it appears.. so i wont. and if i figure it out i'll let everyone know, so if you stay in the car after you shut it off, and maybe have a friend come up and touch the car, see if he gets shocked, if not then it is carried through you.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 03-21-2007, 02:46 AM   #7
mrnickleye
mrnickleye's Avatar
Stephen King comes to mind.
Rim suggestions?? suprafann MKIV Supra 9 06-21-2010 05:10 AM
suggestions for new intercooler. rabidsquirrel MKIII Supra 5 01-19-2009 06:41 PM
No Power At All: Suggestions... panblackrose MKIII Supra 8 05-17-2008 02:15 AM
clutch suggestions B3AN5 MKII Supra 0 10-21-2007 11:28 PM
mod suggestions edelmar417 MKII Supra 3 11-03-2006 02:26 AM
