Old 02-09-2007, 07:08 PM   #1
brs86supra
brs86supra is on a distinguished road
Default need help quick think something is really wrong
think i have a serious problem, my turbo and my turbo manifold is glowing red hot. its never done this before and i also have not downpipe on it, my exhaust stops at the elbow. what could be causing this problem? any help will be greatly apreciated. i checked my timing and it was way off and my afm also went caput today if i plug in the afm it idles and then dies, unplugg the afm and it idles.
brs86supra is offline   Reply With Quote
Old 02-09-2007, 07:31 PM   #2
grygst76
grygst76 is on a distinguished road
LEAN LEAN LEAN timing is way too advanced, AFM dead...repair before you buy a new motor..
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
Old 02-09-2007, 07:35 PM   #3
brs86supra
i have another afm on the way right as we speak its in the mail. my timing was actually below 0. dont ask me how this happened i dont know i set it right last time. and if my afm is bad wouldnt that make me run rich.
Old 02-09-2007, 10:52 PM   #4
abhattan
abhattan's Avatar
Any codes? If the AFM is faulty, then it is probably giving the computer the wrong information. It doesn't necissarily have to go into limp mode.
Old 02-12-2007, 09:01 AM   #5
generally when the afm is faulty it will throw codes
try putting the downpipe back on, just to the cat and see if theres any change then get back to us
Old 02-13-2007, 07:28 PM   #6
IHateHacks
IHateHacks's Avatar
"my turbo and my turbo manifold is glowing red hot"
The exhaust manifold is most likely warped by now. Warpage limits for turbo exhaust manifolds are .0197 in.
Did you set BASE ignition timing? This is done by disabling the electronic advance. Base ignition timing for a turbo 87 should be 10 degrees before top dead center (BTDC).
Old 02-13-2007, 07:43 PM   #7
grygst76
ALSO, with having the DP off you are introducing air up into the O2 housing where the sensor is, it will cause either extremely rich, or lean condition, ask me how i know, I had a bad leak at my manifold in my camaro where the o2 housing was, it ran so rotten it ruined my 02 sensor, and I had to change my plugs...
a glowing header or turbo means the plugs are firing way before they should be, and it causes extreme heat to build up, change your oil when your done too, and you might have to clean your turbo oil lines too, they are possibly coked up now from the oil being well over temp...
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Stock Block Evilfurby MKIV Supra 56 01-09-2006 02:23 AM
