Old 02-01-2007, 08:54 PM   #1
drmmr15
drmmr15 is on a distinguished road
Default Still no boost...
So, I bought my 87 Supra Turbo for cheap ($1000) because the turbo wasnt spooling. I figured it'd be an easy fix. I pulled the turbo, checked for cracks, leaks, etc...and nothing. The turbo spins freely and no shaft play. Before I pulled the turbo, when I drove the car, there was a hissing coming from the turbo area like a leak somewhere. I figured it to be an exhaust leak. So when I put the turbo back on, I kept the downpipe unhooked and started up the car. The hissing was gone, but still no boost. I havent thouroghly inspected the IC piping yet, but that might be the problem. My question is, would an exhaust leak keep the turbo from spooling and give the car no power, or would that be a leak somewhere else? Also, if I had a vacuum leak, would the car die right away, or would it still run, but miss-fire terribly? I would really like to get in touch with a knowledgeable someone in the Seattle-Everett area and just have them come check my car out. As always, money is tight, and a helping hand would be greatly appreciated. Thanks.
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
