Old 10-04-2006, 05:19 AM   #1
thechori
thechori is on a distinguished road
Default 7MGTE vs 1JZGTE
well i was looking for a motor on www.osakajdmmotors.com , and found both of these. the 7MGTE was only $100 cheaper, i was a little suprised, because the 1jz has a better reputation, and it being twin turbo. the only reason i'm shying the idea of it is the lack of parts and aftermarket support.
can the parts from a 7mgte be used on a 1jzgtte? ive heard that parts from 2jzgte can be used on it, but i'm pretty sure those are just a tad more common
and also, if i were to buy just the engine, would finding a 5-speed tranny for the 1jz be relatively cheap/easy to find? and what else would i have to buy
(here's the link to the page..)
sorry if this has already been addressed, but i don't have much time to research and all, also the fact that i can get some direct answers from you guys, given my situation is alot more helpful
which one would you guys suggest? any info would be appreciated :]
thechori is offline   Reply With Quote
Old 10-04-2006, 08:47 AM   #2
first things first... the motor is called a 1jzgte not 1jzgtte
things you must also learn
engine types/models
examples
M series engine
JZ series engine
1G series engine
none of these engine numbers/letters are the same... i.e.. you cannot interchange parts
so to answer your question can 7M parts be used on a 1JZ, the answer is no
can 2JZ parts be used on a 1JZ... yes
your hardest part for the gearbox is finding a jz bellhousing (not sure if you guys get these over there, more than likely do, but you could get a w58 bellhousing from a jza80 non turbo mk4)
otherwise you would be searching in japan for an jz series bellhousing for a r154
good luck with your search
in my biased opinion i would hope that the 7m would prevail
Old 10-05-2006, 01:09 AM   #3
thechori
sorry, on the website it was called the 1JZGTTE, with TT being twin turbo and all that would make some sense (RB26DETT--also twin turbo), or is that just a toyota thing? correct me if i'm wrong
Old 10-05-2006, 01:19 AM   #4
well altho what you thought would make logical sense
you do stand corrected
nissan is TT
but toyota is just T
in the engine numbers they put t as meaning turbo whether it be one two or three
altho i haven't seen three in person yet haha
Old 10-05-2006, 03:09 AM   #5
thechori
alright cool, i've been used to nissans, i just recently picked up my supra so i'm a little new to the toyota scene. i think it should be neccesary to put how many turbos are on the car in the engine code, just so when you mention it you know how much heat you're packin :]
Old 10-05-2006, 03:28 AM   #6
kwnate
single > twins
Nate
Old 10-05-2006, 04:51 AM   #7
thechori
Originally Posted by kwnate
single > twins
why do you say that?
Old 10-05-2006, 04:41 PM   #8
AZN_Pride
AZN_Pride is on a distinguished road
hich one is better??I saw the samething an I am thinking about buying the 1jz but I dont know what I will need to get the motor installed if I get the 1JZ.
90 Turbo MKIII:3"full exhaust(no Cat),MKIV IC, Apexi BoV,Apexi AVCR,550cc injectors, upgraded fuelpump, swaintech coated pistons and rod bearings, JDM folding mirrors and sidemarker lights, Lexus MAF, TRD clutch Kit,and some interior mods.
AZN_Pride is offline   Reply With Quote
Old 10-05-2006, 04:55 PM   #9
Isphius
Isphius's Avatar
Its cheaper and easier to upgrade and rebuild the 7m, And way easier to install. Plus it has more displacement, Which our fat cars need. The only reason id say get a 1jz is if you want a car made of all stock toyota parts that will be faster and last a long time. But if you plan on upgrading stick with the 7m.
Old 10-06-2006, 12:11 AM   #10
kwnate
I guess if you want small hp numbers stick with your twins
Nate
7mgte or 1jzgte parts sr_xaiko MKIII Supra 5 08-14-2006 03:56 PM
1JZGTE or 7MGTE ?? faheemo MKIII Supra 2 05-30-2006 07:59 PM
1jzgte vs 7mgte 86.5_supra MKIII Supra 4 05-11-2006 07:49 PM
7mgte or 1jzgte gpgtp_22 MKII Supra 1 01-29-2006 08:27 AM
