Old 09-30-2006, 09:12 PM   #1
west_side_supra
west_side_supra's Avatar
Default where did i go wrong
ok i have a HKS BOV SSQV, it came with a straight pipe with the flange welded on it, i have this flange put onto the IC pipes up by where the Filterbox is then i blocked off the pipe comeing from the 3000 pipe to the air filter hose with a soild metal cylinder, bought a longer hose for the vacume line and ran is from the stock location of what the bypass valve was hooked up to and ran it to the HKS bov. now when im driving it is cutting out like crazy bogging? fuel cut? boost leak somewhere?
if it may be a boost leak where would be some prone spots to look, and also i would like to add that i am venting to the atmosphere and not useing a HKS recirculation kit if anyone needs a picture please ask i will start taking them
Old 09-30-2006, 09:34 PM   #2
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
leave the stock bov hooked up and have the hks one hooked up separately. if you need to have a 3 prong vacum thing to let you hook two vacum lines to the stock location. i plugged up my bov one time and it ran like shit and wouldn't go past 40 mph. so i would reccomend not plugging it up for some reason it screws everything up.
justin1642 is offline   Reply With Quote
Old 09-30-2006, 09:43 PM   #3
west_side_supra
Default pictures
well ill post some pics anyways
PIC 1: just an overall shot of the setup
PIC 2: the pipe im useing to block off the pipes
PIC 3: i poped open my hood yesterday and this was smokeing, the little rubber houseing AHHH THE PAIN
so where am i wrong on this
Old 09-30-2006, 09:44 PM   #4
west_side_supra
justin i did have it hooked up like that and it was still running the same theres something wrong
Old 09-30-2006, 10:20 PM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
also block the 3000 pipe and intake pipe separately do not join them
we have that same bov and flange pipe on another car here and the bov is loose which will cause a boost leak, make sure it is not loose "at all" as this will cause cutting
have you done a diagnostic?
you do realise that a diagnostic will tell you what is wrong with your car, it is an extremely useful tool that toyota decided to put in our cars
Pics of my build.
Do a diagnostic first!
Old 09-30-2006, 11:33 PM   #6
marc
when you hooked up that bov y did u block off all those pipes?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 10-01-2006, 10:14 AM   #7
west_side_supra
Unhappy
well i was told at my local performance shop to block off those pipes, im not shur really what they do, but just a good guess is that the 3000 pipe blows air while the other one sucks, i dont see why a diagnostics would be in hand considering there is no check engine light on at all, will it still work even though the light is not on?
its really starting to get worse the exhaust is starting to smell bad to the point of where it is burning my nose when you rev it
errr this is really starting to bug me now, mmm suppra how would you say to seal that loose BOV, i mean i could like maby silicone it or something cause im not planning on driving it anymore till i get this issue fixed. and is this bov an issue since im only running the stock amout of boost im reading maby 7-8psi right now its reading about 3-4psi and then it starts to spudder like crazy
p.s. i also noticed some oil spots on my engine cover dont know what type of oil it is, but i did check my engine oil and it was reading almost nothing and just had it done at my mobile 1 about 1 month ago. so im feeling either its leaking or burning
AHHH i cant have this car die yet.
Old 10-01-2006, 10:56 AM   #8
suprra_girl
7M POWAH! ;)
get some oil in there asap altho it may be too late
you will need to get a thicker o-ring if the bov is loose
just see if you can wiggle it, if so.. it's loose therefore buy a thicker o-ring
yes diagnosis does not always throw a check engine light... you may still have codes stored
most importantly.. block those pipes how i told you, not how you have them
i shall explain
air gets sucked in through the turbo, to the intercooler up to the 3000 pipe meanwhile the turbo is sucking the air that is in the 3000 pipe back through to the turbo due to you having it joined
i.e no air is basically getting to the engine, it is overfueling like a mofo and can't run properly
maybe my drawing will help some
Pics of my build.
Old 10-01-2006, 11:04 AM   #9
suprra_girl
7M POWAH! ;)
oh hang on... is that pipe solid? as in no hole in the center?
if so... then do a diagnostic
Pics of my build.
Old 10-01-2006, 04:38 PM   #10
j3pz
solid pipe
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
Wrong oils everywhere Gunnar MKIII Supra 1 01-08-2008 04:08 PM
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
