Old 08-28-2006, 05:24 AM   #1
HEMAN
HEMAN's Avatar
HEMAN is on a distinguished road
Default Bov
I was wondering what BOV i should go with? hks ssq, blitz, greddy? the new hks bov is not able to be manually adjusted; but i also read that the spring action bov aren't that reliable and good; so i just want some feedback to what some peeps are using. thanks
HEMAN is offline   Reply With Quote
Old 08-28-2006, 05:08 PM   #2
Reeves
Reeves is on a distinguished road
A lot depends on what kind of sound you want.
Reeves is offline   Reply With Quote
Old 08-28-2006, 08:51 PM   #3
Cool
get one that recirculates instead of one that dumps excess boost
Old 08-29-2006, 12:47 AM   #4
supra90turbo
supra90turbo's Avatar
err... they're ALL "spring action"...
Old 08-29-2006, 01:06 AM   #5
Isphius
Isphius's Avatar
IMO, the ssqv sounds the best. And since its the kind of valve that pressure would keep closed(puller instead of pusher), Its unlikely to leak boost. But ive never persoanlyl used one, so cant help that much
Old 08-29-2006, 03:15 AM   #6
HEMAN
HEMAN's Avatar
which one recirculates the boost?does the hks sssq recirculates? thanks
Old 08-29-2006, 06:12 AM   #7
Supra2NR
Supra2NR's Avatar
dont get it , im kinda lost
i dunt own a turbo yet but
isnt the whole point of the BOV is to release excess pressure?
so it has to open right?
so if pressure closes it, what opens it?
Old 08-30-2006, 04:13 AM   #8
Isphius
Isphius's Avatar
No, the ssqv doesnt recirculate. There is a forge recirculated one, and some that are 50/50. Most stlyes of valves have a spring holding them closed, And the pressure pushing against the valve. Ie, Pusher(pressure wants to push it open). The ssqv has the pressure from the turbo holding the valve closed, So the more pressure the harder it is to leak. And what opens it is the vaccum on the other side of the throttle body after you close the throttle. Thats what opens all BOVs. It realses the pressure for 2 reasons. When you close the throttle, There is still a large column of air moving under pressure from the turbo through the whole IC and piping to the throttle. If the pressure backs up, It can slow the turbo down. Thats always bad. 2nd, It makes a backwave of air pressure, Which can damage the turbo.
Old 08-30-2006, 07:47 AM   #9
Reeves
I was under the impression that you could set up the ssqv to recirculate.
Whats so bad about having a BOV that just dumps pressure into the atmosphere anyways??
Old 08-30-2006, 06:29 PM   #10
Burn N' Up
Burn N' Up's Avatar
Whether its good or bad is your choice but what happens is all the air the MAF just read gets blown into the atmosphere with every shift but the fuel that was meant for that air still gets injected into the engine so it can cause a little flooding and sometimes stall. Initially i never stalled when i had it, but now with all the work I did to the car I stall once in great while when the car is cold and I shift and when warmed up have a little flame out the pipe from first to second if I'm getting on it. So not a big deal unless you've been taking poor care of the car and back fire really hard. There is an attachment for the HKS SSQV that someone was selling that lets you recirculate if you want.
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
