Old 06-24-2006, 03:11 AM   #1
jaysun
jaysun's Avatar
jaysun is on a distinguished road
Default tranny switch
i have an N/a 1989 supra, STOCKED -_- i want to do a tranny switch from an auto to manual and im just wondering what do i need besides a break,clutch petal, transmmision and fly wheel. and how much it would cost for the swap including labor.
-Jason
7m-ge
auto tranny
non turbo
so far stocked ..
jaysun is offline   Reply With Quote
Old 06-28-2006, 03:37 PM   #2
SupraDriver12790
SupraDriver12790 is on a distinguished road
i used to have an 88 zx auto and hated it so i was going to change swap it to manual and got a quote from a local shop for $1,200 material and labor luckily the auto tranny went out and was to expensive to replace without going over resale on the car so i sold it and got my 87 supra
SupraDriver12790 is offline   Reply With Quote
Old 06-28-2006, 06:34 PM   #3
theWeezL
theWeezL's Avatar
You will need the hydraulics that "push" the system. The Clutch master cyl. and the slave cyl. and all the lines in between. As I understand you do not need to switch the ECU to a manual version, but you may want to swap out the gauge package to a non-auto version to get rid of the now useless ECT, O/D lights.
____________
Old 09-23-2006, 04:33 AM   #4
tone loc
tone loc's Avatar
transmission mount and trans to engine braces
pilot bearing ,cluctch and all that crap in the bell housing and then pedals and hydrolic system and thats about it oh and the manual cluster
Old 09-23-2006, 07:05 PM   #5
rnoswal
rnoswal's Avatar
You are also going to have to cut the shifter hole back about an inch too. The Auto wiring has to be reworked to make the backup lights work along with the park/driving wiring to get it to start. I think the speedo cables work ok but the cruise won't work now with the different pickup mounts. You will need to make a boot cover that goes over the rubber boot to keep the heat out.
I don't think there are any provisions for the clutch pedal enable start switch either. So make sure it is pushed in or in neutral when you start the car. It is a lot of work, but I did it and it worked out pretty good, but I think if I had to do it over again, I would just sell the car and by a manual. The auto is pretty good and it is nice having cruise control.
Good luck
Russ
Old 09-23-2006, 07:37 PM   #6
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
Default car
u will also need the manuel transmission driveshaft because it is shorted than the auto one
Jeff_5_7 is offline   Reply With Quote
Old 09-23-2006, 08:40 PM   #7
tone loc
tone loc's Avatar
some supras are diffrent. before you cut measure first.
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
Faulty Headlight Switch... please help! MusicNazi525 MKIII Supra 4 10-30-2005 12:31 AM
