Old 03-12-2006, 05:56 AM   #1
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
Default boost drop
well i changed to a 3" downpipe and added a walboro 255 fuel pump, i was holding steady at 8psi now it goes to 6 maybe 7 if i am lucky then drops to 4-5.
i changed the gasket that is between the DP and turbo.
i always thought that when you open the exhaust up, it cause a little more boost not a loss.
it still feels strong, it actually feels stronger. i wonder if my guage is just crapping out on me.
if anyone has any ideas, let me know. i would appreciate any feed back.
djalkyd is offline   Reply With Quote
Old 03-12-2006, 06:21 AM   #2
dcrusupra
dcrusupra's Avatar
First thing, get an aftermarket boost gauge. The stock guage responds very slow. Then check to see if you have a boost leak anywhere.
New Rebuild
My CarDomain
Old 03-13-2006, 11:41 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep get an aftermarket boost gauge then measure
did you get a 3" from the turbo or from the turbo elbow back?
is the wastegate opening fully or is it hitting the downpipe
what downpipe did you get?
Pics of my build.
Do a diagnostic first!
Old 03-16-2006, 04:45 AM   #4
djalkyd
djalkyd's Avatar
the down pipe is from the turbo back and it is from cooleeze in canada. they do very nice work to i must say.
i solved the problem though, i am back to 8psi and holding very strong. 3 of my clamps were loose on the charge piping. i cant believe the difference in just adding a down pipe to this car.
i have the new innercooler hard pipe on the way and full exhaust from cooleeze so it should add a little more.
i also got in the ARP head bolts and a 2mm tri metal headgasket form titan so i should have a fun weekend coming up.
Old 03-24-2006, 07:42 AM   #5
1988gte
1988gte is on a distinguished road
Let us know ive been eyeing the cooleeze stuff to
1988gte is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
