Old 03-10-2006, 02:36 PM   #1
HpLover101
HpLover101 is on a distinguished road
Default quick question
what does the lexus afm do?
HpLover101 is offline   Reply With Quote
Old 03-10-2006, 02:56 PM   #2
supra_91
supra_91's Avatar
lets more airflow through
Old 03-13-2006, 11:54 AM   #3
LOL
well you are to the point aren't you
when you install 550cc injectors you now need to either drop them back using an safc or similar so you don't borewash the engine, run rediculously rich or even stall out from the richness
the engine doesn't know that there are 550cc injectors so it can't control them... so you then need something else that will invisibly input air or control airflow/injector duty somehow
this is where the lexus afm comes in
the lexus when installed allows 25% more air to enter the engine which the ecu doesn't know about either
so the invisible fuel and the invisible air end up matching each other and the air fuel ratio is once again even
550cc injectors = 25% more fuel than stock
lexus afm = 25% more air than stock
if you require any more info i'd be happy to help
Old 03-13-2006, 02:20 PM   #4
rnoswal
rnoswal's Avatar
Sounds like magic!!!!!!!
Russ
Old 03-13-2006, 08:02 PM   #5
HpLover101
thanx for the info all 1 more thing...........if i was to add an lexus afm do i have to have the 550cc's? or would it hurt the motor if i didnt have them
Old 03-13-2006, 09:49 PM   #6
well putting it simply
yes you require the 550cc injectors
remember, with the lexus there is 25% more air getting in that the ecu doesn't know about
therefore the ecu can't correct the fuel for it... so you end up running lean, and the car doesn't really run anyway
Front Strut Bar - Quick Question Grandavi MKIII Supra 6 09-25-2008 06:03 PM
Quick question 88ProjectSupra MKIII Supra 1 04-24-2008 11:56 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
