Old 03-11-2006, 08:04 AM   #1
The_Black_Beast
The_Black_Beast is on a distinguished road
Default speed\cruise control limiter removal
hello
I was just wondering how to remove the speed\cruise control limiters out of the 1989 3.0gt limited supra.
Thankyou
The_Black_Beast is offline   Reply With Quote
Old 03-13-2006, 11:49 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i have a blitz speed defencer for your car which is a straight plug in... all you need to wire in is an earth
if you are interested lmk
otherwise
speed limiters are available from various retailers... hks, blitz, greddy etc
Pics of my build.
Do a diagnostic first!
Old 03-13-2006, 02:22 PM   #3
rnoswal
rnoswal's Avatar
Just curious, what is this limiter for or what does it prevent?
Russ
Old 03-13-2006, 04:32 PM   #4
Troyota
Troyota is on a distinguished road
^It eliminates the factory speed limiter (governer). I don't think any USDM MkIII Supra's have one from the factory as I've seen both N/A and Turbo cars do 150 MPH w/o difficulty. However in other countries and on other models perhaps there is a Speed limiter programmed into the ECU. For example the 1JZGTE that I am currently installing into my '87 has a factory speed cut at around 120 MPH. A speed cut controller intercepts the signal to to the ECU and tells it you are traveling slower than you actually are so you bypass the speed cut limit.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 03-13-2006, 10:20 PM   #5
rnoswal
rnoswal's Avatar
Thanks for the information!
Russ
Weired Cruse Control Issue Chambers MKIII Supra 4 07-01-2008 02:11 PM
top speed limiter removal? marmlr339 MKIV FAQ 7 05-25-2008 06:38 AM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
Lost control of my car today. redmaro Off Topic Forum 5 01-19-2007 05:04 PM
