#1 |
7M POWAH! ;)
reason i asked is because depending on which you are then determines where water hoses and pipes are located in your engine
i would probly check the one under #1 intake runner check the hoses going from the throttle body.... use your hand and follow them do they have stains on them from leaks are they currently leaking
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#2 |
Well again with the pressure tester, they are kind of expensive and if a close auto parts store has a tool loaner deal, try that first. Try all of them close to you and just make sure they have the adapter that fits the smaller cap on our supra's. I think these testers are close to $150.00 and you don't get to use it that many times.
Just an idea anyway. Russ |
#3 |
Thanx Suprra Girl I replaced one of the lines when I did the gaskets but the other looked and felt fine so I left it I cannot feel anything on it but I can't really reach it well either so I am going to put it on jack stands and try to get at it again tommorow as I don't have school after work then and can get some daylight hopefully.
I'm going to keep trying to find it without the tester for now as no parts place around here that I know of rents tools. Thanx again for the help both of you! |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Heater Union (Coolant Leak) | slader99 | MKIII Supra | 11 | 12-28-2009 12:29 AM |
| Coolant Leak | bossman | MKIII Supra | 2 | 04-12-2008 09:31 PM |
| Coolant leak issues | D_Train | MKIII Supra | 1 | 03-15-2007 04:30 AM |
| Mysterious Coolant Leak | Yoterman | MKIII Supra | 3 | 12-18-2006 03:30 PM |
| MKIII coolant leak HELP | sportriderseattle | Non-Generation Specific Questions | 2 | 12-21-2005 06:12 AM |
