Old 02-28-2006, 04:41 AM   #1
Nato99
Nato99 is on a distinguished road
Question One piece drive line...
I'm thinking of changing to a one piece driveline, and getting rid of the carrier bearing, so I'm curious if there are any con's. I've already got most of the pro's from the vendor Any advice??
Thanks
88' MKIII
HKS cold air intake
HKS electronics
Turbo Tech Turbo
etc, etc.....
Nato99 is offline   Reply With Quote
Old 02-28-2006, 02:01 PM   #2
rnoswal
rnoswal's Avatar
Can't think of any cons. Lighter and no carrier bearing or extra U-joints has to be a plus. Seems like all the serious fast guys go that way eventually. Get it, it is a major plus for the drive train.
I guess the only thing might be its strength. Really sticky tires and a lot of power like 500 hp or so, does the manufacturer state that it can handle that or more. I am sure it can, but you might ask, unless they already said that was no problem. If not, then I wish I could afford one, because I would definately get one.
Russ
Old 03-03-2006, 08:28 PM   #3
Nato99
I thought it sounded like a win/win situation but I wanted to double check. The manufacturer says it's good to 650hp
Old 03-04-2006, 05:09 PM   #4
Burn N' Up
Burn N' Up's Avatar
If its lighter you might loose an 1/8th of a gallon per mile, hehe.
Blown line going to EGR Morty MKIII Supra 11 01-13-2008 12:42 PM
my 87t's first drive j3pz Non-Generation Specific Questions 0 07-21-2007 01:51 AM
one piece drive shaft mizuboi MKIII Supra 1 09-23-2006 03:35 PM
Help with Drive Axles on mk4 n/a to tt swap dini_the_owl MKIV Supra 5 09-14-2006 11:29 AM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
