Old 10-10-2014, 06:25 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
Code 12 - No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked. - Trouble Area: Distributor circuit, Distributor, Stater Signal circuit, ECU.
Sounds like the cam sensor is busted or the circuit is cut. It is in the distributor. The only cam/crank sensor is in the distributor, so a busted sensor means not start.
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
TPS code 41... Cyberguy1992 MKIII Supra 0 04-26-2011 08:14 PM
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
