Old 01-04-2014, 04:58 PM   #1
kpotmk3
kpotmk3 is on a distinguished road
Default no fuel...
Just bought an 87 turbo car and I'm not getting any fuel the guy I bought it from was driving it and it died on him. I've got spark and compression just no fuel. Any ideas?
kpotmk3 is offline   Reply With Quote
Old 01-09-2014, 10:54 AM   #2
supraguy760
supraguy760 is on a distinguished road
Have you tried bridging the b+ to the Fp pins in the diagnostic box to see if the fuel pump is dead?
supraguy760 is offline   Reply With Quote
Old 01-09-2014, 12:34 PM   #3
kpotmk3
What pins go to fp I havent really had time to check it out because by the time I get home from work its dark and freezing cold lol
Old 01-09-2014, 08:11 PM   #4
supraguy760
By the battery there is a diagnostic box, remove the black/grey cap and look at the cap. There is a diagram of which pin is which. Use a small piece of wire to bridge the two pins, you should hear the fuel pump engage if you are in a quiet enough area.
Old 01-14-2014, 05:38 AM   #5
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Also, the ignition switch needs to be in the on position just long enough for the test. You should hear the fuel in the rail getting past the regulator (near the oil cap). As soon as the jumper is pulled, the sound stops. If it frozen cold, you may have water in the line thats frozen. In that case add a bottle of isopropyl alcohol gas line antifreeze (not rubbing alcohol which is part water).
Can I just buy a fuel pump filter? leftfoot MKIII Supra 8 08-11-2015 05:09 AM
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
