Old 10-31-2013, 12:00 AM   #1
7MGTReeds
7MGTReeds is on a distinguished road
Default need help w/Bee-R rev limiter
I'm having an issue with my BEE-R rev limiter on my 89+ supra 7MGTE. the damn thing just doesn't seem to work correctly. i have tried wiring it in numerous configurations and the only one that yields me a partial result is the configuration from this link which is JZA70 specific:
http://www.supramania.com/forums/sho...70-specific%29
i currently have it wired into the ECU in the configuration from the above link which is:
Red wire - +B
Black wire - Battery ground
Yellow wire - NE
Green wire - IGF
right now the rev limiter works however it is rev limiting at idle (bouncing idle from 650 rpm) it will not let me go past 1000 rpm on any setting, on any knob. when i put the yellow gain knob back to zero (0) the rev limiter deactivates and runs as if there was no BEE-R installed, which is what it's supposed to do. i have also tried to intercept the other 3 igniter wires which are IGT, IGDA, and IGDB and all yielded the same results above. also tried wiring the way the BEE-R instructions say to do and i got zero results.
i need some help from someone who has installed one of these on a 89+ 7MGTE. i know there is a few guys out there that have these installed because I've seen the videos on youtube! i just need some direction on how to wire this thing up! thanks!
7MGTReeds is offline   Reply With Quote
mk2 speed limiter possum MKII Supra 0 05-05-2010 05:03 PM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
Rev limiter and Dyno curves carl johansson MKIII Supra 1 11-19-2007 06:21 PM
Speed limiter cut greddy defender old dude MKIII Supra 5 04-08-2007 07:48 PM
speed\cruise control limiter removal The_Black_Beast MKIII Supra 4 03-13-2006 10:20 PM
