Old 09-30-2013, 12:02 AM   #1
DakotaHyde
DakotaHyde is on a distinguished road
Default Replacing a 7MGE with 7MGTE
Hello, I have an 87' MK3 with stock 7MGE. I am looking to purchase a 7MGTE for replacement. I am wondering if anyone knows what all this job entails, will I need to modify any wiring harnesses, what needs to be done with the computer, etc.. Thank you very much for any assistence!
DakotaHyde is offline   Reply With Quote
Old 09-30-2013, 04:29 AM   #2
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
So as for the swap, i do know that there are a couple of things you will have to do. Some being a 7mgte ecu, r154 trans, maybe the driveshaft as well, an intercooler system; cause you are going turbo now, maybe fuel pump cause the 7mgte will need a more efficient way of obtaining fuel, and I'm sure there's a lot more.
Hope this helps!
1989 Toyota Supra Turbo w/ Targa Top
White Exterior-Blue Interior
3" Blitz Catback Exhaust System
BIC Divorced Downpipe, Straight Pipe
Megan Track Coilovers
Apexi BOV, Turbo Timer, and Intake
Lexus Projector Fogs
Bride Low Max Replica
S-mk3-B is offline   Reply With Quote
Old 09-30-2013, 03:56 PM   #3
DakotaHyde
Hope this helps!
Thank you for all this information, I have a question though. I have the stock 4-speed automatic, will it be necessary for me to replace this with the r154? This is actually my biggest concern. The engine im buying has the intercooler with it.
Also, the cc is the same for both engines, but will the 7GMTE require different mounts? Or will it essentially drop right in the old space. Also, would it be to my advantage to look into a better radiator? It is original stock as well.
Old 09-30-2013, 07:36 PM   #4
S-mk3-B
S-mk3-B's Avatar
I believe you will need the r154 because the 7mgte will be dishing out more power and torque, which is where the r154 will come into play, and if it's a manual trans then that extra 5th gear would be good to have. And to my knowledge it should be an easy drop right in, haven't heard that you have to modify the mounts of any sort. And anyone please correct me if I'm wrong.
But again hope this helps!
Old 10-01-2013, 02:08 AM   #5
The A143E should be fine. There was a beefier version but I think that may have more to do with the year than the engine trim. The 7M-GTE also has an oil cooler and recommend you don't try to go without it. A fair amount of the things you're going to need to look out for will depend on the year of your car and the year of the engine and ecu/wire harness. The pre89 models used the same mounts and the 89+'s different mounts.
Old 10-04-2013, 12:14 AM   #6
if you have a w58 (5 speed) it will work fine, it is used on 1j and 2j non turbo engines through the years. i believe the 7mgte uses a different clutch than the non turbo.
Old 10-04-2013, 03:35 AM   #7
Originally Posted by DakotaHyde View Post
I have the stock 4-speed automatic, will it be necessary for me to replace this........
Not sure what part of this everyone keeps missing....
Tags
7mge swap
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
