Old 04-05-2007, 11:54 PM   #7
godmachine
godmachine is on a distinguished road
Default same problem!
Originally Posted by blitzmkiii
the speedo dont work, the gas gauge will only go to half a tank, ......, temp always on hot, oil pressure is messed up, but the tach works perfect
i just bought an 87 turbo with aftermarket gauges, and it has almost exactly the same problem!! i'll try these suggestions to fix it, but i wanted to ask, did you ever end up solving this? if so, did you pinpoint the exact problem?
thanks!
godmachine is offline   Reply With Quote
TRD Gauges Help needed ladyangel MKIV Supra 1 06-24-2008 11:12 PM
new gauges Supra2NR MKIII Supra 6 09-19-2007 06:06 AM
Aftermarket Gauges Boombastic MKIII Supra 0 08-25-2007 10:52 PM
Gauges Burning Pyro MKIII Supra 3 07-21-2007 07:07 AM
