Old 10-07-2005, 03:37 PM   #1
blitzmkiii
blitzmkiii is on a distinguished road
Default my gauges r screwed!!
Hey wats up i have had aftermarket gauge cluster pretty much ever since i have had the car ( about a year) and a little while back all my gauges went crazy! They are all screwed up the speedo dont work, the gas gauge will only go to half a tank, the boost gauge is on -6 till i redline then it shoots up to 6, temp always on hot, oil pressure is messed up, but the tach works perfect anyways my ques is me and a friend took the cluster out and checked it out the wiring looks fine we think the needles went bad if so can i replace the needles or do i have to get a new cluster and how would i know for sure if it is the needles????
1987 5-speed Turbo, JDM 7M-GTE, K&N air filter, 3' straight exhaust, Blitz BOV, Upgraded CT26 Turbo, 3' Down Pipe, NGK Iridium Spark Plugs And Wires, Megan Racing Strut Bar
blitzmkiii is offline   Reply With Quote
Old 10-07-2005, 04:25 PM   #2
SupraMan1784
i dont think its the needles...though i may be wrong...imma still go wit the assumption that its electrical...even though u say the wiring is wrong..did u check the connections? make sure everything is tight and there are no frayed wires...which i assume there are none since u checked the wiring..make sure all the connections are tight
Now: Saving for an MKIV
Broken Rides:
Old 10-07-2005, 04:39 PM   #3
blitzmkiii
thanx man im goin to check again im just trying to get everything perfect im puttin a new 7m in my car in bout to weeks and im buyin alot of extras lol just tryin to get everything done right been savin for a few months
Old 10-07-2005, 05:07 PM   #4
joel w
joel w's Avatar
check the ground cables. battery to block, block to chassis chassis to exhaust, there is lots of electronics that need a good grouind. just a thought
Old 10-08-2005, 05:51 PM   #5
supra_91
supra_91's Avatar
theres no way it's the needles
Old 10-08-2005, 11:44 PM   #6
joel w
joel w's Avatar
Question
i would focus on one problem at a time, first the fuel gauge, take the sending unit out of the tank from the top inside the car under the rear carpet toyo was smart and put in an access door for us. 3 screwes on the cover and 3 or 6, 10 mil bolts for the sending unit. pull it out carefully and manually move it full range while someone watches the gauges with the key on. mine had varnish built up on the reistate wireing wrap that the float arm rubs against. once i carefully scrapped the varnish off, the arm made contact with metal again. 2 years now and it still works fine. make sure the float is still sealed with air and (floats) and not half full of fuel. see if that fixes one issue? and go from there...
Old 04-05-2007, 11:54 PM   #7
godmachine
godmachine is on a distinguished road
Default same problem!
Originally Posted by blitzmkiii
the speedo dont work, the gas gauge will only go to half a tank, ......, temp always on hot, oil pressure is messed up, but the tach works perfect
i just bought an 87 turbo with aftermarket gauges, and it has almost exactly the same problem!! i'll try these suggestions to fix it, but i wanted to ask, did you ever end up solving this? if so, did you pinpoint the exact problem?
thanks!
godmachine is offline   Reply With Quote
Old 04-07-2007, 06:31 AM   #8
supramacist
supramacist's Avatar
New gauges is the fix.
TRD Gauges Help needed ladyangel MKIV Supra 1 06-24-2008 11:12 PM
new gauges Supra2NR MKIII Supra 6 09-19-2007 06:06 AM
Aftermarket Gauges Boombastic MKIII Supra 0 08-25-2007 10:52 PM
Gauges Burning Pyro MKIII Supra 3 07-21-2007 07:07 AM
