Old 06-12-2012, 07:25 AM   #1
Ozz9186
Ozz9186 is on a distinguished road
Exclamation Please help --Coolant leak at rear of engine.
Hey everyone I'm new on here but my question is I have a 87 supra 7mgte and I'm leaking coolent some were behind the motor I checked all the hoes around the rear and they looked good im lost please help
Ozz9186 is offline   Reply With Quote
Old 06-17-2012, 10:05 PM   #2
This was posted in thw wrong section. Please folks, before you post a new thread make sure you are in the right section. Also search to make sure it wasn't already discussed.
Thread moved to the MKIII forum.
EDIT: Also, please use DESCRIPT TITLES. This way I dont have to spend time reading about things I know nothing about.
Old 06-17-2012, 11:17 PM   #3
Green7mgte
Supra Forum Moderator
check the 90 degree hose directly above the egr cooler.. bet thats your culprit. go rent a rad pressure tester.. or just pucker up to your rad and see where the air comes out at.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-18-2012, 12:55 AM   #4
907mge
907mge's Avatar
Also check the heater union on the back of the head. When I did my HG I found it was leaking.
Old 06-18-2012, 08:27 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Ditto: as previous members post suggested.
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
88 Non-Turbo coolant leak Tazman3653 Non-Generation Specific Questions 1 03-30-2009 02:09 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
