Old 12-16-2011, 01:32 AM   #11
Reaper6193
Reaper6193 is on a distinguished road
Does anyone know what the pins are called that are put in the cams to keep the timing gears from slipping?
Reaper6193 is offline   Reply With Quote
Old 12-16-2011, 06:01 AM   #12
Dowels.
P/N
90250-05121
Old 12-16-2011, 06:06 AM   #13
Reaper6193
I told the dumbasses at toyota that and they told me there was no such thing on a 91 supra.....good thing I walked out of there haha....so does anyone know there dimensions so i can have a machine shop down here make me to....and what the best metal to use would be thanks.....
Old 12-16-2011, 06:11 AM   #14
I just gave you the part number, you could just tell them to order the things and save the lip.
Otherwise, they're about 1cm long and approx 5mm in diameter. Take a cam gear to the machine shop and tell them you need an alignment dowel for it and they should have no problem setting you up. If the gear is properly torqued there is insufficient force to shear even a mild steel dowel, but cold rolled would be my minimum preference.
Old 12-19-2011, 06:11 PM   #15
Reaper6193
Ok, how do u time this piece of shit engine?.....I'm trying to do the timing on this engine and it keeps jumping...
Old 12-19-2011, 08:55 PM   #16
Of course I do... but it'd be quicker if you look in the FAQ section.
Old 01-11-2012, 03:42 AM   #17
Reaper6193
Car is running fine with a occasional pop in my exhaust, but the car won't boost right in first gear and then when I shift into second the car drops and hits 12 lbs in the tap of the pedal.....is that jus the boost lag or could it be something else?
Old 01-12-2012, 12:02 AM   #18
87hilux7mge
87hilux7mge's Avatar
sounds like a timing issue. just kinda wierd you get no boost in 1st, and the hammer drops in second. any boost or exhaust leaks? backfiring still makes me wanna think timing...
Deteriating Problem, Car turning over but just wont start Jamie MKIII Supra 1 09-24-2010 01:27 AM
