Old 12-09-2011, 02:54 AM   #1
Reaper6193
Reaper6193 is on a distinguished road
Default Problem Turning Over
I just finished fixing my head gasket on my car and reinstalling everything......now the car won't start or turn over.....all it does is make a click noise.....I think that i'm missing a ground wire some were and that the reason it won't turn over.....any suggestions on were this pesky wire might be located at?
Reaper6193 is offline   Reply With Quote
Old 12-10-2011, 10:54 PM   #2
If it's not turning over at all, start with pulling the EFI fuse and verify that you can rotate the crank (to make sure something in the powertrain isn't locked up.
Then check the primary ground from the engine to the battery and the power line from the battery to the starter (there are two wires which run to it: primary and solenoid, the solenoid obviously has power).
Old 12-11-2011, 03:46 PM   #3
agreed make sure your starter is fully connected and is properly grounded.
Old 12-12-2011, 06:20 AM   #4
Reaper6193
Now I got the engine to crank....but no my head is leaking from the exhaust side.....If i didn't torque the head bolts down to the right specs will that cause it to leak or is it time to replace my heads?
Old 12-12-2011, 09:02 AM   #5
87hilux7mge
87hilux7mge's Avatar
What's did u two the head bolts too...?
Old 12-12-2011, 10:31 PM   #6
Reaper6193
Well No it starts up and is running with no check engine light, but is pouring out oil from somewere but I can't find were.....any ideas?
Deteriating Problem, Car turning over but just wont start Jamie MKIII Supra 1 09-24-2010 01:27 AM
