Old 09-13-2011, 06:10 PM   #1
alarsen77
alarsen77 is on a distinguished road
Default BHG question.
Hey guys I have an 89 auto n/a supra with a bhg I am just looking to get the car running right not do any crazy upgrades. I am planning on just using a stick gasket and arp head bolts and having the head machined. I am just wondering do I have to do anything to the block or is there anything else I need to do while doing this job? I am trying to keep cost down as money isn't readily valuable right bow but these needs to get done shortly. I am just looking for some advice and if there is anything else that is recommended I look at or replace while doing the head gasket that may restore lost horsepower.
alarsen77 is offline   Reply With Quote
Old 09-14-2011, 12:25 AM   #2
As long as there's no significant pitting or indentions then just follow the TSRM and inspect for warping and flatness. Make sure it's very clean too. I'd thoroughly clean the carbon build up off of the piston crowns while you're in there too... Mopar Combustion Chamber Conditioner (MCCC) works well as a soak to loosen it up; Just spray and let it sit a couple hours, while out and repeat.
Absolutely do not forget to chase the threads in the block! And do not forget the RTV at the block/rear timing plate union!!! These are biggies!
Old 09-14-2011, 05:35 AM   #3
supraman3000
supraman3000's Avatar
supraman3000 is on a distinguished road
hey cre can u explain what is chase threads!
thanks im kinda learning cre going 4 auto tech soon!
I HAVE TO GET SUM KINDA BELT LOL!
supraman3000 is offline   Reply With Quote
Old 09-14-2011, 06:10 PM   #4
A thread chase is essentially a non-cutting tap. It's used to reshape and space threads. If you don't have a chaser or can't find one you may use a tap, just be very careful getting it started as it will cut new threads and mangle the existing ones if you don't get it in straight. (NEVER use either with a drill! Hand power only!) Lubricate it well and remove it and clean it about every 1/4" to prevent shavings and dirt from chewing up the threads. Then when you're ready to install lube the hell out of the bolts with the included moly grease and torque in steady, even passes.
I'm just going to cut and paste what I've posted before:
75 ft lbs with moly and the threads MUST be chased. Torque in multiple passes 3 - 5 and if you encounter striction back off an eighth up to a quarter turn and resume. Each pass should go smoothly, if it stutters or jumps (striction or static friction) then it's not lubed well enough, it's binding on the threads or you're moving too slowly... It will usually result in false torque readings.
Retorque after a few hundred miles:
http://www.toyota-supra.info/forums/77288-post10.html
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Quick question prior to ordering parts Grandavi MKIII Supra 16 07-07-2010 05:17 AM
mk3 transmission question/ tire question.. rohin02 MKIII Supra 5 04-04-2010 08:25 PM
oil leak question ftwmotorsports MKIII Supra 9 02-12-2010 03:53 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
