#1 |
Hi! Re : earth wire :
From memory , I made up a new earth wire because my old one was in a very poor condition , by drilling a hole to fit a new self-tapping screw between the coil leads for easy screwdriver access at the front of the plate and then measuring and making a new lead to fit the inlet manifold clamp-up bolt/nut on the cylinder head . It's a very good idea to check the continuity at this point as it is now very easy to repair/check/clean -not forgetting that the plate is electrically insulated by the rubber mounting grommets . No starting problems now , especially since I fitted the relay mod to the starter, kicks in every time now! |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help...My spark plugs are in the oil !!! | chinesedawn | MKIII Supra | 6 | 10-03-2011 09:25 PM |
| Spark Plugs and Water | cgreiner | MKIII Supra | 1 | 07-21-2009 03:49 AM |
| NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
| how to check platnum spark plugs | suprabahamut | Non-Generation Specific Questions | 0 | 05-02-2007 05:42 AM |
| 1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
