Old 09-22-2005, 08:46 PM   #1
deaclen
deaclen is on a distinguished road
Default RPM Problems
A buddy of mine just gave me his non turbo-ed 86 Supra. I don't know much about these cars and i generally work on domestic vehicles. Any way i was wondering if you guys might have an idea of what would cause a vehicle not to go over 2500 rpms. I though maybe it has a built in rev limiter that is malfunctioning. A bad sensor, bad computer, not enogh fuel and a few other things. My bud already pulled the engine out of it though so i don't know for sure until i reinstall it. I did not think it was going to be neccessary for him to do that but oh well we shall see. Let me know what you guys think. NE and all help would be most appreciated.
deaclen is offline   Reply With Quote
Old 09-23-2005, 02:14 PM   #2
rnoswal
rnoswal's Avatar
Well, it could be timing, either cam or distributor. It could be a clogged fuel filter too. Make sure the butterfly is opening all the way and that there is nothing clogging the intake anywhere. Was it missing or running smmoth but just not revving up?
The cams and pistons are non-interference so they could be set wrong and still run but very poorly. Oh yeah, a clogged exhaust could cause that too, especially the cat. converter. Let us know.
Russ
Old 09-24-2005, 12:16 AM   #3
WiseAssJester
Question
Is the 7m a non-interference motor in that a piston at TDC wont slap a valve in its complete open position?
Old 09-24-2005, 06:30 AM   #4
rnoswal
rnoswal's Avatar
Yeah, that's it. The valves won't catch each other nor will they contact the head if the belt breaks. It is a nice feature, but it does mean there is room for a compression improvement either with the head or with high compression pistons. Of course then you will give up that safety margin, but the extra power may be worth it.
Russ
Old 09-24-2005, 02:43 PM   #5
not going over 2500rpm = limp home mode
timing belt jumped... ign timing way off
along those lines more than likely
Old 09-26-2005, 07:38 PM   #6
monkihead
monkihead's Avatar
have you checked for vaccum leaks?? try by the head/manifold gasket & injector rubber o-rings. mine was loose by two bolts did the same thing.
monique- better off dead
Old 10-05-2005, 06:35 AM   #7
khanh1315
khanh1315 is on a distinguished road
Default Tps bad
You should check your TPS. Try cleaning it or replace a new one. if tps is not good, rpm wont go over 2500rpm
khanh1315 is offline   Reply With Quote
Old 10-05-2005, 04:16 PM   #8
rnoswal
rnoswal's Avatar
So what did you find?
Russ
Old 10-11-2005, 12:11 PM   #9
robbie
robbie is on a distinguished road
Lightbulb
i have had same problem it will stutter a bit then sit on 2500 the more u accelerate the lower the rpm goes ....... the only way to stop it without replacing n e thing was to turn off the car and re-start i wasnt too shure what solved my problem after i had a full service but my money is on your throttle position sensor ... give it a thorough clean and check your fuel filter.....
robbie is offline   Reply With Quote
Old 10-13-2005, 04:26 AM   #10
A plugged exhaust will cause an engine to not rev past a certain point. I repaired (replaced cats and mufflers) many on the 22R engine from the late 70s and into around 86 Celicas and trucks. Not many supras, but a posibilty.
