Old 04-26-2011, 12:02 AM   #1
SawDustCharlie
SawDustCharlie is on a distinguished road
Default oil pump went out. HELP!
the oil pump went out on my 87 7m! i got it home and took off the oil pan the next day. i did find a teensy bit if metal shavings in the pan. i hope its just the rings fried and NOT the cylinders scored.
and help on this? i want to rebuild the motor but i need some advice
SawDustCharlie is offline   Reply With Quote
no power to fuel pump carcrzy920 Non-Generation Specific Questions 0 06-05-2009 05:51 PM
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
