Old 04-19-2011, 08:03 PM   #1
cfurlan
cfurlan is on a distinguished road
Default About to give up
I bought a 87 supra turbo that was freshly rebuilt. Well the kid did not put a thermostat in it so I installed one. I took it for a test drive afterwards and it overheated right away. Later I noticed that the rubber plug on the back of the engine blew out. Car was running very badly and would not stay running without giving it gas. I then pulled the whole motor and did a complete rebuild with bearings and seals. I had the head checked at the machine shop and it was all in spec, and it was resurfaced on the previous rebuild. I put it all together and the car barely ran and was missing very badly. After two months of not working on it a came across a parts car. So I redid the head gasket and changed the head, coil packs, plugs, wires. It is still missing badly. I have great compression with new je pistons and rings. Fuel pump is working great with great fuel pressure. I am getting great spark on all cylinders. I checked, double checked, and triple checked the timing. I know it is perfect. As of now the car will not stay running on its own, I have to give it a little gas. I've also check all the vacuum lines and they are all good. Please if anyone can help I will be greatly appreciated. Next I'm going to swap out ecu's to see if that will help. It is not throwing any codes at all. My name is Chris. If it's easier you can call or text 574-387-1777. Thanks
cfurlan is offline   Reply With Quote
Old 04-19-2011, 09:33 PM   #2
Tried running it with the airflow meter unplugged?
Old 04-19-2011, 09:35 PM   #3
cfurlan
Not yet, I will try that real quick.
Old 04-19-2011, 10:02 PM   #4
cfurlan
By unplugging it, it made it worst to where it did not want to start at all. It would go put put put and then die every time. Even when trying to give it a little gas.
Old 04-20-2011, 03:15 AM   #5
Conga1991
Well it's not the sensor or plug on the afm then.
Old 04-20-2011, 03:08 PM   #6
vbryanv
vbryanv is on a distinguished road
have you tried the idle air control valve (iac)
vbryanv is offline   Reply With Quote
Old 04-20-2011, 03:17 PM   #7
Ranma
Ranma's Avatar
Talking
You could always put up some money and let the dealer fix him. Sometimes we get so focused we miss the oblivious. So support your local Toyota dealer and let them correct the problem.
Old 04-20-2011, 04:16 PM   #8
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
seems like your better off doing a engine swap.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
gloreboy89 is offline   Reply With Quote
Old 04-20-2011, 06:11 PM   #9
Have you done a compression test?
Old 04-20-2011, 07:23 PM   #10
cfurlan
I will do another compression test today
What turbo would give me the most power at 6-8psi supraman121 MKIII Supra 9 09-11-2007 12:45 AM
I give up... EpilepticPuppy MKIII Supra 13 09-08-2007 06:45 PM
head gasket gone would it give oil in turbo intake johnkarl MKIII Supra 7 10-31-2006 06:38 PM
Can some of you guys give me some info on these cars? Big Jimbo MKIII Supra 5 01-07-2006 08:24 PM
parts that will give me the biggest hp increases wikdMK3 MKIII Supra 6 05-04-2005 03:42 PM
