Old 04-14-2011, 05:20 PM   #1
graywolf1969
graywolf1969 is on a distinguished road
Default help i cant find any good bov kits on ebay for a 7mgte
Does anyone know were i can find a bov kit that well fit my 7mgte does any know some web sites
graywolf1969 is offline   Reply With Quote
Old 04-15-2011, 03:07 PM   #2
turbonicsperformance
if you run a bov your car will more than likely stall between shifts...
that being said ebay is full of bov's and kits just search bov and the first page has 9-10 kits that come with the bov and a pipe with flange already fitted
http://cgi.ebay.com/ebaymotors/SSQV-...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Type-...Q5fAccessories
Old 04-15-2011, 04:04 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
If you didnt get it from the critism on your last post then I will spell it out for you......
YOU CAN'T DO IT ON A STOCK 7MGTE ECU. IT LOOKS FOR THE AIR BETWEEN SHIFTS. IF YOU IGNORE THIS ADVICE YOU CAR WILL RUN LIKE SHI, BACK FIRE AND SOMETIMES SHUT OFF. AND YOU WILL HAVE WASTED YOUR MONEY ON A BOV!
If you want your car to go psshh. Then buy a srt4 neon!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 04-16-2011, 08:43 AM   #4
87hilux7mge
87hilux7mge's Avatar
^^^correct.
the GTE uses a KVAFM (karman vortex air flow meter) b4 the turbo, and that tells it how much air is coming into the system. if you create a too-atmosphere leak then the car will be receiving less air than it thinks its getting, and therefore, load up on fuel and cause stalling, poor idle, etc etc..
then only way to run a bov on a gte is to run a standalone system or delete the kvafm (not cheap and not easy, respectively).
sucks but thats the way it goes.
Old 04-16-2011, 11:19 PM   #5
Any piggy back with tip-in and tip-out fuel controls allow you to tune this problem out to a good degree... it's just another $300 you weren't planning on spending.
Some people boast nothing but the occasional backfire, but I wouldn't count on being one of the lucky ones.
Old 04-17-2011, 12:25 AM   #6
87hilux7mge
i wouldnt wanna go that way, thats kinda like band-aiding a knife wound..
Old 04-17-2011, 01:15 AM   #7
mkiiisupra
Adding a BOV to your 7mgte will not affect your idle in any way...
Venting to atmosphere will cuase you to run rich when shifting. This can cuase stalling and other issues, people have added a BOV with varying results.
Do it right, Do it once..
Buy nothing from ebay...
Stock BOV functions fine with stock turbo and fuel system...
Think about your upgrade order and do not piss on your limited(assuming since your on ebay) funds.
http://www.toyota-supra.info/forums/...mk3-supra.html
Good places for parts
www.horsepowerfreaks.com
www.titanmotorsports.com
www.driftmotion.com
www.arizonaperformance.com
www.beechperformance.com
www.bicperformance.com
www.rockauto.com
www.shop.retro-spec.net
www.mvpmotorsports.com
www.toyotaworld.com
http://www.jscspeed.com/
There are plenty of places that support the supra community and dont make cheap chinese low quality parts...
1990 Toyota Supra Turbo A/T
Question regarding a 90 7MGTE Grandavi MKIII Supra 3 06-25-2010 05:42 AM
auction car scams suprra_girl Buy/Sell Cars 7 07-19-2009 10:57 PM
