Old 04-13-2011, 03:00 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Default electrical ? for 7mgte
hello im in the process of a 7mgte swap and im wondering what all wires can be deleted since im not gonna be running a/c or have the stock cluster i have
knock sensors wired
afm
ignitor
injectors
tps
cps
coils
o2 sensor
autometer oil/water
miata tach (oh yeah the swap is into my miata)
(which coolant sensor do i need for the computer?)
and what else do i NEED to have it running i have deleted the isc and there is like 10 coolant sensors also where is my map sensor is it a external sensor?
thanks for any answers,
Nick
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 04-13-2011, 04:28 PM   #2
You need to keep the stock oil sensor and the speedometer (or figure out a way to generate a compatible speed signal for the ECU).
The coolant sensors are detailed in a number of posts here, try searching "coolant sensor location"... the ECU sensor is the one which must remain.
There is no MAP sensor on the 7M, just the KVAFM. The boost sensor is not used by anything but the boost gauge; It does not supply any info to the ECU.
I'll let someone else chime in with the rest. Good luck!
Old 04-13-2011, 05:44 PM   #3
alright thanks
what type of signal am i supposed to get from the speed sensor is it a halifax sensor or am i gonna get a voltage/ohm reading from it?
Old 04-18-2011, 04:49 AM   #4
That would be a Hall Effect sensor and yes, I believe so. On the 5spd equipped ECU's I "think" it's just used for cruise control, ABS and might be used as a minor fuel trim modifier.
The oil pressure sensor is used as a critical fuel and timing control. This signal is pretty much static and significantly dampened inside the sensor.
Old 04-19-2011, 02:43 AM   #5
alright well i went ahead and wired in the oil psi sensor (i find it wierd that its important, but not gonna argue with facts)
what exactly happens without a speed sensor? I don't have cruise, nor abs but have been reading on here that people get odd idle from it (though i've blocked off my isc) so idk if i really "need" it
Old 04-19-2011, 04:59 AM   #6
Just put it on a dyno and do a couple pulls with it and a couple without it and check to see how much the timing and fueling shift (if any); I'm not sure about the complete scope of it's affect on engine operations.
The oil pressure signal is not uncommon in modern vehicles at all... in most vehicles it's far more critical. I don't know if the TCCS does any "sanity checks" if not then you could put together a bandaid to run without it... it's probably just easier to leave it though.
Old 04-21-2011, 02:57 AM   #7
idk about the dyno thing it would get expensive fast, but for now im just gonna run without it and see how it works out. ill just wait and figure it out from trial and error. then once i get the cash im gonna run a maft pro or possibly hold off a little longer and run aem/ms
electrical problem! I think!!!!!help!! Boostcrazy61 MKII Supra 0 08-21-2009 12:08 AM
Needing some electrical help happysupraowner:) MKIII Supra 3 04-19-2009 01:16 AM
Electrical Troubleshooting go.stfu MKIII Supra 0 10-21-2007 09:32 PM
Oil Pressure...Mechanical or Electrical??? Luvs2slide MKIII Supra 5 08-23-2006 12:42 AM
Intermittent Electrical Problems on a ’93 MKIV gjs_cds Shops & Part Reviews 0 05-22-2006 02:39 PM
