Old 03-31-2011, 11:02 PM   #1
83Billygoat
83Billygoat is on a distinguished road
Default cluster/gauge light
what is the light in the upper left corner of the gauge cluster. It looks like a carocelle. just curious
83Billygoat is offline   Reply With Quote
Old 04-01-2011, 12:28 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
You mean like a carousel or a bird cage? That's the low coolant light. The sensor is in the reservoir. It goes on hopefully before the coolant gets low in the radiator.
Old 04-01-2011, 03:22 PM   #3
83Billygoat
you don't know of any codes affiliated with this light.
Old 04-01-2011, 04:15 PM   #4
The "birdcage" light will not come on with any codes, it is just a low coolant light. Make sure your radiator is full, then fill the reservoir to the "Full" line and it should go away.
Dome Lights btwilson86 MKIII Supra 6 04-03-2011 01:05 PM
Dome Light? SuperX MKIII Supra 4 02-02-2010 11:49 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
