-   -   cluster/gauge light (http://www.toyota-supra.info/forums/mkiii-supra/18897-cluster-gauge-light.html)
83Billygoat 03-31-2011 11:02 PM
cluster/gauge light
what is the light in the upper left corner of the gauge cluster. It looks like a carocelle. just curious
Busted Knuckles 04-01-2011 12:28 AM
You mean like a carousel or a bird cage? That's the low coolant light. The sensor is in the reservoir. It goes on hopefully before the coolant gets low in the radiator.
83Billygoat 04-01-2011 03:22 PM
you don't know of any codes affiliated with this light.
btwilson86 04-01-2011 04:15 PM
The "birdcage" light will not come on with any codes, it is just a low coolant light. Make sure your radiator is full, then fill the reservoir to the "Full" line and it should go away.
